20 Most Recent Maxent MX-26X3 Television Questions & Answers
If power reaching unit and after all you have checked, it appears the PS is fubar. Easiest thing to do is check for swollen/leaking/blown capacitors and replace them - cross your fingers and turn on.
Maxent MX-26X3... | Answered on Sep 04, 2017
Code for gateway works. I used 206 on my universal remote. I have a Phillips remote.
Maxent MX-26X3... | Answered on Jan 03, 2014
Do you have a digital converter box? Its a smaller block square box that connects to the wall and the tv connects to the digital converter? I you do not have a digital converter that is most likely your problem. Not a gurantee but since they did the big digital signal switch, you now need these converters. Hope this helped
Maxent MX-26X3... | Answered on Jan 01, 2014
26 inch maxent mx-26x3 and 32 inch, l2614xw02 some same parts
When i hear the word static, i think snow,
If while your watching tv and it looks like color snow pixels popping in and out all over the picture i did this to fix it.
look at main board you see a green heat sink,
left of that heat sink you see a 220 uf 16 volt capacitor that half surround by 22 uf capacitors,
change the 220 uf capacitor and snow is gone.
to get it off i just wiggle slowly back in forth until the old capacitor falls off,
then put some fresh solder on and new capacitor on and done.
use a radial electrolytic capacitor not the little metal one they had on
tc
bagabillion
Maxent MX-26X3... | Answered on Oct 10, 2012
what are you looking for? If someone answered a prior question make a comment there or here describing what you need to know.
Maxent MX-26X3... | Answered on May 28, 2012
The tv probably does'nt have a fast enough refresh rate to work with games properly. It should be in the manual for the tv, the lower the number the better. I think it's 12 milliseconds on that tv. Have a look here:Response Rates.
Maxent MX-26X3... | Answered on Apr 15, 2012
i have had the same problem with the dark patch and found out it was because i had a speaker sat too close to the tv!!!
Maxent MX-26X3... | Answered on Feb 12, 2012
someone gave me a maxent mx26x3 with the same problem. I took the back cover off, and then the metal shield covering the PC board. There is a green heat sink on the main processing chip. The heat sink was not making good contact. I slightly twisted and pushed the heatsink on the the chip, and the picture stayed perfect now for 2 days. I think the heatsink will eventually need to be re-glued on with thermal expoy glue. It will be a pain to remove and clean though.
Maxent MX-26X3... | Answered on Jan 11, 2012
Maxent ,mx 26 x3 turns on for 5sc.( all white) then picture flickers and screen goes black.. green light on throughout..none of button on the remote or the tv will work expect the power .i wonder is their a way to reset the tv?
Maxent MX-26X3... | Answered on Aug 21, 2011
Here's the LINK.
Maxent MX-26X3... | Answered on May 19, 2011
yes you can and fromwhat i see you have the right connection on the monitor so you dont need any special adapters - you just need a 15pin VGA cable with audio (mini phono for audio) male for all connections on both sides of wire
connector should look like this
images?q=tbn:and9gcrnfpwdbn3a_ozkr8hzprr_0j3o4i2krz2rpdz4etcsoyfnzl-ojljg5oa
wire should look lilke this
images?q=tbn:and9gctsz2vwsxpd1w5napqnc2bhy7vmotwfe6wqhougqythkgf7tbamghnselmx
hope this helps
good luck!!
Maxent MX-26X3... | Answered on Mar 29, 2011
Problems on your video board and also maybe power supply problems, the caps in most of these sets are the blame. So look for bad caps, you tube has video on how to fix some sets
Maxent MX-26X3... | Answered on Jan 03, 2011
More than probably is the LCD control board, but this one is coming with the LCD panel. Could be the main PCB too and I suggest you to call a tech for a exact diagnosys because the parts implied are very expansive.
Maxent MX-26X3... | Answered on Dec 29, 2010
Televison & Video Logo
58 questions posted
Top Maxent Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Eric Rotmil
Eric Rotmil
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Maxent Televison & Video
Most Popular Question
maxent mx 26x3 video issue
  • Televison & Video
