20 Most Recent JVC HD-52Z575 52" Rear Projection HDTV-Ready Television Questions & Answers
The parts diagram for the JVC HD-52Z575 is available here: https://www.searspartsdirect.com/model-number/HD-52Z575/1758/0333200.html . The lamp is part TS-CL110UAA. I don't see a separate ballast. If you look at the parts list for the cabinet, a Service manual is available.
I hope this helps.
JVC HD-52Z575... | Answered on Feb 20, 2018
If you wish to get some details; visit the site linked here. Pull up older posts.
JVC HD-52Z575... | Answered on Oct 07, 2017
Hey guys, had the same problem. Found this solution on the web. Worked for me.
JVC HDMI Port Fix
Turn the TV on, and enter the Service Menu. Select 2 for Self Check. Then turn the TV off, and after the fan turns off, unplug the power cord. Reconnect the power cord, turn the TV on, and the HDMI port is reenabled.
Here’s how to get to Service Menu:
Before entering the SERVICE MENU, confirm that the setting
of TV/CATV SW of the REMOTE CONTROL UNIT is at the
"TV" side and the setting of VCR/DVD SW of the REMOTE
CONTROL UNIT is at the "VCR" side. If the switches have not
been properly set, you cannot enter the SERVICE MENU.
1) Press [SLEEP TIMER] key and while the indication of
SLEEP TIMER 0 MIN is being displayed, press
[DISPLAY] key and [VIDEO STATUS] key (Fig.2)
simultaneously.
2) The SERVICE MENU screen of Fig.1 is displayed.
3) Verify what to set in the SERVICE MENU, and set
whatever is necessary (Fig.1).
Refer to the SERVICE ADJUSTMENT for setting.
4) Press the [BACK] key to return the SERVICE MENU.
This should work.
JVC HD-52Z575... | Answered on Dec 08, 2013
You might want to check and see if that was the right lamp for that tv. You might have the wrong lamp
JVC HD-52Z575... | Answered on Nov 18, 2013
u need the real remote rm-18g hit menu till u get to lamp reset hit enter a screen will come up that says press ok to reset lamp timmer hit ok button than another screen will come up that says the lamp timmer was reset successfully
JVC HD-52Z575... | Answered on Sep 19, 2013
You both will need to have a service center come out to try to reset the TV using the reset jig. A JVC authorized service center will be the only ones that will have access to and training to use this jig. It is a good chance reseting it fix the color problem but it could also be something more serious.
JVC HD-52Z575... | Answered on Sep 06, 2013
I have that same problem...we replaced the lamp and nothing happens we hear the fan go on but it goes of .
JVC HD-52Z575... | Answered on Jul 11, 2013
The solution is an easy fix. Ignore anyone telling you to take it to a service center or to replace the convergence driver. You need to access the service menu on your television by using your remote control:
DRIVE CONVERGENCE Adjustment (Using remote control)
•Use the inner RGB box pattern.
(1)Set the [SLEEP TIMER] key to 0 min.
(2)Press the [DISPLAY] key and the [VIDEO STATUS]key simultaneously.
(3)Press the [9] key to display the RGB box pattern.
(4)Select the R mode by pressing the [DISPLAY] key.
(5)Adjust the R mode to setting as same as G mode bypressing the [CH ]+ / [CH -] key.
(6)Select the B mode pressing by the [DISPLAY] key.
(7)Adjust the B mode to setting as same as G mode bypressing the [VOL] - / [VOL +] key.
(8)Check to see that the cross pattern is white. If thecross pattern is not white, readjust (5) to (6).
That's it, your color is now corrected. Yes, I know...your welcome.
JVC HD-52Z575... | Answered on Dec 06, 2012
Hello
You have to download the service manual to your tV to get these details. Try to download it from internet. It will be an impossible link to get as free download. Most of the service manual sites will be paid one.
JVC HD-52Z575... | Answered on Feb 07, 2012
Thats usually an issue with the receiver power board.
JVC HD-52Z575... | Answered on Jul 12, 2011
JVC HD-52Z575 52" Rear Projection HDTV-Ready Television Logo
74 questions posted
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
i2c stop accidentally entered in service
  • Televison & Video
