20 Most Recent
JVC AV-60D501 60" Rear Projection Television Questions & Answers
The picture on the TV
No adjustments ,from wehat you are saying you have a leaky capacitor in the vertical circuit 100uf 35v, 1uf 50v, 4.7uf 50v and you might have Poor Solder connections on vertical IC.
TV yesterday worked ok, then last night it would
This is a power supply issue.
Most likely an onboard relay has failed.
We suggest taking all TVs in for professional service - as they store potentially lethal amounts of energy that needs to be released properly before work begins.
This repair should be completed for under $100 if the power supply can be repaired. You are looking about $400 if the P/S needs replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
I have a 60 jvc
Sounds like the same problem i have...
I believe its the AC Power Regulator that needs to be replaced.
Looking into finding out how much this costs...
AV-60D501
There is a 5, 9 & 12 volt dc regulator on the
chassis that could be causing this. Three legged
transistors on small heat sinks. I f you look at the chassis from the rear of tv, is two boards.The one on the left has these reg. transistors. Usually the 9v regulator is bad
and a 35ufd @ 50v capacitor near it is bad.
From the tuner as ground check the third leg
on the regulator for less than 9v dc.
JVC AV-60D501
From what you're describing your focus block is probably failing JVC p/n#129P059050. It's probably also very vibration sensitive. They're about $80.00 dollars and they are also interchangeable with the Mitsubishi focus pack p/n#920p016010. Not a difficult repair - we do about 5-6 a month. Real easy in-home repair.
Hope this helps.
Bill
TV will not power on.
Sorry my friend but I had this problem. You definately have to get a repairman out to fix it. The AC voltage regulator has gone bad. Good news is it will cost about 225 bucks to fix which is ALOT better than buying a new TV.
JVC 43" (109cm) HD Ready Plasma TV PD43N30A. Chunghop universal remote codes for JVC pd43n30a
Question edited for a lot more clarity, plus
Chunghop not chungCHOP :>D
JVC: 089, 161, 909
CHUNGHOP Universal Remote Control Codes
codesforuniversalremotes.com
https://codesforuniversalremotes.com > chunghop-univer...
Jul 25, 2019 -
CHUNGHOP Universal Remote Control Codes ; Aiwa: 009, 057, 058 ; Samsung: 618, 619, 620, 621 ; Philips: 013, 023, 024 ; Hisense: 676, 677, 707, 898
My JVC TV has an onscreen remote that doesn't let us use the actual remote what do I do to gat it out?
Hello! If your JVC TV is displaying an onscreen remote and you're unable to use the actual remote, you can try the following steps to resolve the issue:
- Power cycle the TV: Turn off the TV and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This can often reset any temporary issues and restore the functionality of the actual remote.
- Replace the remote batteries: Check the batteries in your remote control and make sure they have enough power. If the batteries are low, replace them with fresh ones and try using the remote again.
- Check the remote control sensor: Ensure that there are no obstructions between the remote control and the TV's remote control sensor. Clean the remote control sensor on the TV with a soft, lint-free cloth to remove any dust or debris that may be interfering with the signal reception.
- Reset the TV to factory settings: If the issue persists, you can try resetting the TV to its factory settings. Keep in mind that this will erase any personalized settings and restore the TV to its original configuration. Refer to the user manual or the manufacturer's website for instructions on how to perform a factory reset on your specific JVC TV model.
- Contact JVC customer support: If none of the above steps resolve the issue, it's recommended to reach out to JVC customer support for further assistance. They will have access to more specific troubleshooting steps and can guide you through the process of resolving the issue with the onscreen remote.
Keep in mind that the exact steps and options may vary depending on your specific JVC TV model. Refer to the user manual or contact JVC customer support for model-specific guidance.
