20 Most Recent JVC AV-65WP74 Rear Projection Television Questions & Answers
Pin cushion distortion. It is an internal circuit fault. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts.
JVC AV-65WP74... | Answered on Apr 11, 2017
Not the lamp if u have good picture.Ur 2 convergence ICS and all the resistors is dead.Colors misaligns,have shadow or 3D colors. Must replaced 2 ICS and all it resistors in the US shop will cost U $300 parts and labors.Canadian don't know.
JVC AV-65WP74... | Answered on Oct 09, 2016
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
JVC AV-65WP74... | Answered on Nov 26, 2014
Convergence output Ic's and check associated low ohm resisters, replace any that are open.
JVC AV-65WP74... | Answered on Dec 30, 2013
If you Don't know...
Then you should NOT even attempt to measure it!!!
YOU CAN EASILY BE KILLED!!!!
THIS VOLTAGE IS NOMINALLY IN EXCESS OF 30,000 VOLTS AND WILL KILL YOU!!!
JVC AV-65WP74... | Answered on Jan 27, 2013
If the model indicated here is right It could be in the power supply and this model sometimes fails where light just blinks--that could be also convergence issue--in this model there is a way to disconnect the power going to the convergence board to see if set will then turn on.
JVC AV-65WP74... | Answered on Jun 14, 2012
Thats a convergence issue which is common for all rear projection models. The AV48WP74 - AV65WP74 convergence repair kit from www.tvrepairworld.com will usually solve convergence issues. The kit contains both ICs and the associated resistors and the CD with repair instructions.
JVC AV-65WP74... | Answered on Sep 15, 2011
Convergence ICs and resistors need replacement. Very common issue. The AV48WP74 -AV65WP74 convergence repair kit from www.tvrepairworld.com has the 2 ICs and associated resistors plus the CD with repair instructions.
JVC AV-65WP74... | Answered on Aug 17, 2011
The clicking you hear is probably caused by a relay that controls the incoming AC to the main power supply. This is a protective reaction to a problem in the power supply itself or an overload due to a failure downstream from the supply. This is not a likely DIY repair. You will probably need a technician to determine which of these two likely problems it is.
JVC AV-65WP74... | Answered on May 19, 2011
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
JVC AV-65WP74... | Answered on Apr 22, 2011
  • Screen looks 3D
Here are some images of convergence problems.
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself.
JVC AV-65WP74... | Answered on Apr 21, 2011
did you check the low ohm resistors. A JVC will almost always blow at least one and if the ICs are replaced without replacing the resistors the new ICs will fail instantly
JVC AV-65WP74... | Answered on Mar 04, 2011
The convergence ICs have failed. You can get the JVC AV48WP74 - AV65WP74 convergence repair kit from www.tvrepairworld.com which has the ICs and resistors plus the CD with detailed repair instructions.
JVC AV-65WP74... | Answered on Nov 10, 2010
Yes it is worth fixing . You can fix it yourself for about $ 21 . You need to replace the convergence I.C. chips , The part # is STK392-310 . you need two of them . You can get them from bluestar-online.com . They are about 6 bucks a piece and about 10 for shipping .
JVC AV-65WP74... | Answered on Sep 12, 2010
See attached photo of what convergence board in your set looks like and the chips that fail; it is directly behind front panel beneath the screen--access from the front.
I can tell you exactly how to get at it and what is involved in the repair---TOTAL PARTS COST ON EBAY will be under 25 dollars.
If you want assistance and this information and the photos helped you rate this solution as very helpful.
I have done dozens of these sets with the same problem.
SD TECH
6a2f165.jpg view of board removed from set--back side; note the two black chips to the left.
view of board removed from the front side.
View of board from back side; note the two chips and the protect resistors just in front of them.
sd tech
JVC AV-65WP74... | Answered on Aug 22, 2010
You can download and print the operating manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
JVC AV-65WP74... | Answered on Aug 15, 2010
the service manual for this TV should help to solve this problem. Visit then below link and select the service manual for your TV. If you don't find that of your TV model, you can check that of a closely related model as it should perform the same function:
http://www.e-servicemanuals.com/product-search.php?searchcat=monitors&startnum=300
Good luck.
JVC AV-65WP74... | Answered on Jul 15, 2010
JVC AV-65WP74 Rear Projection Television Logo
112 questions posted
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
jvc hdtv model av 65wp74 tv
  • Televison & Video
