20 Most Recent
JVC XV-S302 DVD Player Questions & Answers
Some dvds no longer play
well, seems like your laser diode is getting old. you need to change the diode. what you are experiencing is the start of a dying diod. it will start to rejects cd and soon enough it will not spind at all on all the cd's. so change the emitting diode. good luck
Jvc dvd player
seems like you put an NTSC dvd movie in there and the machine is set to Pal or the other way around. you need to program your computer to multi region setting. check the website for the unlock region codes. good luck
Remote code
try to search for the code manually. it should work. good luck
Jvc xv-s302 only plays black and white
Look at the back of the DVD player it should have a NTSC & PAL switch ,but remember to switch off the dvd player after you change it over to NTSC or PAL
i hope this will help you
craig:)
DVD XV-S302
hi
what is the way you are getting the sound to your tv? is it audio video composit cables ?
or scart one ?
try to get new scart or change between the cables to decide which one is broken
try to shake the scart from the side of the tv set
it is propably a connection fault !!
please don't forget to do excelent rate cause i here to help you
regards
JVC 43" (109cm) HD Ready Plasma TV PD43N30A. Chunghop universal remote codes for JVC pd43n30a
Question edited for a lot more clarity, plus
Chunghop not chungCHOP :>D
JVC: 089, 161, 909
CHUNGHOP Universal Remote Control Codes
codesforuniversalremotes.com
https://codesforuniversalremotes.com > chunghop-univer...
Jul 25, 2019 -
CHUNGHOP Universal Remote Control Codes ; Aiwa: 009, 057, 058 ; Samsung: 618, 619, 620, 621 ; Philips: 013, 023, 024 ; Hisense: 676, 677, 707, 898
