20 Most Recent Casio Pathfinder PAS410B5V Wrist Watch Questions & Answers
0answers
Replacing watch band on pathfinder pas410
Watchmakers use special tool to release spring bars, but it is possible to release them in home conditions. Place your watch on flat surface face down. Using pocket knife insert the blade between band and the watch lug where the spring bar (pin) end is and using lever action push spring bar end inwards. This should release the band from the watch. If all this does not work, then your watch band is attached with friction fitted pins and you will need watchmakers help, as without special pin removing tool it is not possible to remove friction fitted pins.
Rate me, plz.
1/8/2010 9:01:19 PM • Casio Pathfinder... • Answered on Jan 08, 2010
I have a Casio Pathfinder 2805. The glass display screen is dirty on the inside. How do I remove the display screen to clean the inside?
Question edited for clarity. Question moved from Casio Business Machines. It is a job best left to a local jeweler when it is battery change time. The fact is got dirty inside means there must be damaged gaskets. If you want to do it yourself, remove the back and lift the movement out, being careful to not damage the button contacts. https://www.google.com/search?q=Casio+pathfinder+2805+remove+movement ..
4/9/2022 11:42:29 PM • Casio Pathfinder... • Answered on Apr 09, 2022
How to reset 2872 casio ?
If a Casio watch has a display readout that says "OPEN", the watch isn't closed properly. Check if all the parts are inside the watch and make sure the watch is tightly screwed shut. If the watch was serviced at a repair center you should return it to have it checked (for missing parts).
3/24/2015 3:42:40 PM • Casio Pathfinder... • Answered on Mar 24, 2015
How do set Casio model 6054 gw1000b
On the Casio website, this model 6054 isn't recognised. With the module number (you'll find it in a small rectangle on the back of the watch case) you can download the manual for your watch here: Timepieces Watches Manuals CASIO
3/24/2015 3:16:01 PM • Casio Pathfinder... • Answered on Mar 24, 2015
0answers
0answers
After 5 days of darkness, watch will not turn back on
The watch has a rechargeable power cell inside the cover. Remove the back, find the button batter, and replace it. It may be the old original or dead cell. Once you replace the cell, the watch will refresh and be back to normal. The only problem if that fails, the mini-computer brain died.
12/25/2013 3:12:33 AM • Casio Pathfinder... • Answered on Dec 25, 2013
Change time
What model Casio watch?
11/12/2013 12:32:30 AM • Casio Pathfinder... • Answered on Nov 12, 2013
0answers
Casio Pathfinder PAS410B5V Wrist Watch Logo
3 questions posted
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Pathfinder Casio
  • Pathfinder Casio
Most Popular Question
replacing watch band pathfinder pas410
  • Watches
