20 Most Recent
Casio F91W-1 Wrist Watch Questions & Answers
Casio F91-W how do I reset the display?
A bit late but... There are connections on the PCB that you need to short to ground. Top right of the screen resets the watch. Middle one resets the screen. When you have assembled the watch you can see the holes on the white plastic part.
Please help me to replace battery on my casio F-91W
This reset trick works with other Casio Alarm Chrono digital watches,
such as my old Model W-720, similar to your F91-W. After the new lithium coil cell is
installed and secured with the spring clip, the watch may show random
segments in the LCD display or may simply be blank. Insert a sewing
needle, paper clip, or blade of a small jeweler's screwdriver into the
hole on the back of the movement stamped "AC" (All Clear) to
momentarily connect the gold plated contact at the bottom of the hole
to the stainless steel battery clip. The battery clip in most such
Casio watches is connected to the "+" terminal of the coin cell. This
will reset the CMOS chip and it should start up with the watch
displaying 12:00 and the date at 1-1. Then, use the control buttons to
set the time and date in the normal fashion.
Turn off alarm
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
How can you make a "Casio f-91w" watch not beep
Push the lower left button. The alarm time is showing.
Press the lower right button and it will cycle the hourly beep and alarm on/off.
Press the lower left button to exit when the setting are what you want.
24 hour time
With the time showing, press the lower right button.
This switches between 24 hr and 12 hr every time you press the button.
How to set time on casio 593
click this link for manuam
http://www.usersmanualguide.com/manuals/casio/qw415,587,590,593,595,596.pdfhttp://www.usersmanualguide.com/manuals/casio/qw415,587,590,593,595,596.pdf
Turn off alarm
you need to look at the user manual that you can download a soft version of the user manual on below link. .when you open the link
just write the 4 digits code on the back side and click searched on the URL below
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Lost manual, need to set
Hi,here is the user manual..
soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
Thanks
PDF format.
