20 Most Recent
Vision Fitness - Elite T9450 HRT Folding Treadmill Questions & Answers
Machine not running but lights coming on ok. There was a noise before this happened. Would it be the motor
All question need full 'make model (what it is)', Margaret, first 3 words or this happens.
Fluke BT5300 Series Battery Tester
Fluke
https://www.fluke.com > product > battery-analyzers
Specifications: Fluke BT5300 Series Battery Tester ; BT5310/BT5311, BT5320/BT5321 ; Digit, 6.5 digits, 7.5 digits ; Range, 10 V ; Max. Display value, ±11.00000V · ± ...
(BT) Air Baltic 5310 Flight Tracker
FlightStats
https://www.flightstats.com > flight-tracker
BT5310 Flight Tracker - Track the real-time flight status of Air Baltic BT 5310 live using the FlightStats Global Flight Tracker.
Airbaltic BT5310 Flight Status
Trip.com Official Site ' Travel Deals and Promotions
https://us.trip.com > ... > Flights from Munich to Lisbon
Track real-time flight status of BT5310 from Munich to Lisbon on Trip.com. Get live updates on flight arrival & departure times and other travel information ...
QC620 Skid Digger Thumb
GLC Equipment
https://www.glcequipment.ca > product > qc620-skid-dig...
SKU:
BT5310 - 48 Category: Back Trenchers. MPN: BT5310. Manufacturer: Wallenstein. Brand: Wallenstein. Description; Additional information; Reviews (0) ...
$910.00 · In stock
BT 5310 - Aluminum Komatsu WA450-6 Wheel Loader ...
C, G, & J Inc
https://cgj.com > product > bt-5310-aluminum-komatsu...
BT 5310 - Aluminum Komatsu WA450-6 Wheel Loader Radiator. $1,404.75. The BT 5310 all aluminum radiator is an exact fit, OEM replacement for Komatsu WA450-6 ...
US$1,404.75
Olympus Sport exercise bike, model OS-11202. Resistance braking (gear/level change) is not working.
If the resistance braking system on your Olympus Sport exercise bike model OS-11202 is not working, there could be a few potential issues causing the problem. Here are some steps you can take to troubleshoot and possibly fix the issue:
- Check Power Source: Ensure that the exercise bike is properly plugged into a power source if it requires electricity. Some models may have electronic resistance systems that need power to function.
- Inspect Resistance Mechanism: Examine the resistance mechanism to see if there are any visible signs of damage or wear. Look for loose cables, broken parts, or anything that appears out of place.
- Test Resistance Levels: Try adjusting the resistance levels on the bike to see if there is any response. If the resistance levels do not change when you adjust them, it could indicate a problem with the resistance mechanism or the control panel.
- Reset the Bike: Turn off the exercise bike, unplug it from the power source (if applicable), and wait for a few minutes. Then, plug it back in and turn it on again. Sometimes, resetting the bike can resolve minor issues.
- Check User Manual: Refer to the user manual for troubleshooting tips specific to your model of exercise bike. The manual may have information on common problems and how to fix them.
- Contact Manufacturer or Support: If you're unable to resolve the issue on your own, consider contacting the manufacturer or customer support for assistance. They may be able to provide further troubleshooting steps or advise you on repair options.
- Professional Repair: If the resistance braking system is still not working after attempting these steps, it may be necessary to take the exercise bike to a professional repair technician. They can diagnose the problem more accurately and perform any necessary repairs or replacements.
By following these steps, you should be able to identify the cause of the resistance braking issue on your Olympus Sport exercise bike and take appropriate action to resolve it.
Screws of fitbit charge HR not coming out using a replacement band screwdiver kit
It sounds like you're having trouble removing the screws from your Fitbit Charge HR using a replacement band screwdriver kit. Here are a few things you can try:
- Apply Pressure: Sometimes, screws can be quite tight. Make sure you're applying enough pressure while turning the screwdriver to loosen the screws.
- Use Lubricant: If the screws are stuck due to rust or debris, a small amount of lubricant (such as WD-40) applied to the screws might help loosen them.
- Different Angle: Try turning the screwdriver at a slightly different angle. Sometimes this can make it easier to grip and turn the screw.
- Use a Different Screwdriver: If the screwdriver provided in the kit isn't working well, you might try using a different one. Sometimes, the quality of the screwdriver can make a big difference.
- Seek Professional Help: If you're still having trouble, it might be best to seek assistance from a professional, such as a watchmaker or jeweler, who has experience working with small screws and delicate electronics.
If none of these solutions work, it's possible that the screws are damaged or defective. In that case, you might need to contact the manufacturer for further assistance or consider replacing the device altogether.
I have inspire hr Fitbit. Can I swim with it
Yes, absolutely! You can swim with your Inspire HR. In fact, it is designed to detect your swim activity if you like to swim laps and turn that activity on (you can do it in the app under "exercise goals").
Nordic Track 1300 commercial elliptical. Why can't I level up the resistance?
Check the Generator Tension Bolt :
Loosen the cap screws and tighten the generator tension bolt with an Allen wrench.
Adjust it until the drive belt inside the pedals is no longer loose. If it's too tight, loosen the generator tension bolt as needed.
Retighten the cap screws and replace the side shields.
Unplug your elliptical from the power outlet and examine the wire harness connections between the console and the resistance motor. Check continuity using the multimeter and replace any non-working wires.
Inspect the Resistance Motor Voltage:
There is a small motor under the shroud that operates the resistance motor. It's about the size of a roll of half dollars.
Use a multimeter to check if the console is sending power to the resistance motor when you manually adjust the resistance. If there's no voltage, your elliptical console may need replacement.
If this doesn't resolve the issue, you might contact Nordic support.
I need assembly instructions for wynne home gym.
Please check this link:https://www.google.com/search?sxsrf=ALeKk02D68ibDlpmqPFTdJFsPUAG8G7Hqg%3A1609823462652&source=hp&ei=5vTzX9vmJfG4mAXst4l4&q=assembly+instructions+for+wynne+home+gym&oq=assembly+instructions+for+wynne+home+gym&gs_lcp=ChFtb2JpbGUtZ3dzLXdpei1ocBADMgQIIxAnOgcIIxDqAhAnUIwSWIwSYPUXaAFwAHgAgAHwAYgB8AGSAQMyLTGYAQCgAQGwAQ8&sclient=mobile-gws-wiz-hp
What is the maintenance required for folding exercise bikes?
Cleaning: Regularly wipe down the frame, seat, pedals, and any other accessible surfaces with a damp cloth to remove sweat, dust, and debris. Avoid using harsh chemicals that may damage the bike's finish.
Lubrication: Apply lubricant to the moving parts such as the hinges, pedals, and resistance mechanism according to the manufacturer's recommendations. This helps prevent rust and ensures smooth operation.
Tightening: Periodically check and tighten all bolts, screws, and nuts to prevent loosening during use. Pay particular attention to the folding mechanism to ensure it remains secure.
Inspecting: Examine the bike for any signs of wear or damage, such as frayed cables, worn pedals, or loose components. Address any issues promptly to prevent further damage and ensure safety.
Storage: When not in use, fold the bike properly and store it in a clean, dry area away from moisture and direct sunlight. This helps prolong its lifespan and prevents corrosion.
Battery maintenance: If your folding exercise bike includes electronic components such as a display console, ensure that the batteries are replaced as needed to maintain proper functionality.
Regular servicing: Consider scheduling periodic maintenance checks with a professional technician to ensure all components are in good working condition and to address any potential issues before they escalate.
Promaster pro plus 2 error code 31
Error 31 on your Promaster Pro Plus 2 treadmill could indicate a variety of issues, such as a problem with the motor or the motor controller. Here are a few troubleshooting steps you can try:
- Power cycle the treadmill: Turn off the treadmill and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on again. Sometimes, simply resetting the treadmill can resolve error codes like Error 31.
- Check the motor connections: Make sure all the wires and connections to the treadmill motor are secure and properly connected. Loose connections could cause error codes to appear.
- Inspect the motor controller: The motor controller regulates the speed and operation of the treadmill motor. Check for any visible signs of damage or overheating on the motor controller. If you notice any issues, you may need to replace the motor controller.
- Contact customer support: If you're unable to resolve the issue on your own, it's best to contact the manufacturer's customer support for assistance. They can provide specific troubleshooting steps for your treadmill model and may be able to offer a solution or arrange for repairs if necessary.
By following these steps, you can hopefully resolve Error 31 on your Promaster Pro Plus 2 treadmill and get it working again.
