20 Most Recent
Casio DB36-1AV Wrist Watch Questions & Answers
Replace battery on Casio DB-36-1AV
Open the back (4 screws). Careful with the rubber seal and spring inside. Use a pin to pry the battery clip away from the bottom of the battery. You need to pry the bottom out and up. When the clip releases, the battery is easy to remove/replace.
Can not turn off alarm
If you have Alarms on, you will see a small bar above the Alarm numbers (1 to 5).
Press the Mode button to get to Alarm mode. You will see Bell AL on the top. Use Reverse/Forward to switch to the Alarm you want to turn off. The Alarm number will increase/decrease on the right of the time.
Use the 12/24Hr button to cycle through the Alarm options.
When the Alarm bar is blank, the alarm s/b off.
Note: The Casio manuals are online.
http://www.manualslib.com/manual/221397/Casio-Db36-1av.html
I've removed the back of
There is a clip over the battery and then down on one side. You need something tiny and sharp... like a needle. You can insert the needle into the clip between the battery and the outside edge of the clip and gently pry the clip out and away from the battery.
I have a casio quartz amw-320r can you please tell
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Turn off alarm
go to alarm mode and choose the alarm (1-5) using the "forward" and "reverse" buttons, then hold the bottom right button down to toggle it on or off
Re Casio Waveceptor watch
limited info generic answer if its the lower $ end units-- pop off the back --and remove internals careful of springs for buttons --check for debris -failed spring-button bi-metal fail /damaged
How to fix Quartz on my casio 708 mtp 3036
This is a job a specialist watch repairer should do. It will need specialist tools so if you are not familiar with working on watches pay someone to do it for you. Also consider the cost of repair. It might be cheaper to simply buy a new watch.
