20 Most Recent Loewe Articos 55 55" Rear Projection Television Questions & Answers
The best way to reset your hardware is to actually contact the Manufacturer. Ask how to reset the TV to FACTORY Settings. Original settings are generally the basic and best method to view TV from the start.
Loewe Articos 55... | Answered on Jan 11, 2018
Make sure all Airways do not have alot of dust builted up blocking Airways this can cause Lamps to Blow, also keep in mind these sets are only desinged to play between 5000 to 8000 hrs you cannot leave them on day and night like regular TVs,and yes New Lamp does not mean that it was not Defective sometimes companys do have a run as to where they have alot of defective Lamps it Happens
Loewe Articos 55... | Answered on Nov 21, 2013
Bad Lamp Mats has them for $99.00 1-800-628-1118
Loewe Articos 55... | Answered on Aug 09, 2012
www.tvrepairworld.com has colorwheels for samsngs and other makes.
Loewe Articos 55... | Answered on Sep 27, 2011
The "first thing first" dose the word "LAMP" LED light indication it is lite up or blinking on the tv front of the tv bazel frame?Yes,than the tv projection Lamp life are ended or ur tv has not been replaced the tv projection Lamp like the last 1 1/2 or 2 years and tv been used it daily like 4 or 5 hours every day?Both of this suituations must require ur tv projection lamp replacement.
Loewe Articos 55... | Answered on Aug 19, 2011
Look on Ebay or Try Encompass Parts Distribution 1-800-638-3328
Loewe Articos 55... | Answered on Apr 04, 2011
It is critical thet you replace the cooling fans! The imagers will be damaged if you don't. The focus issue is possibly contaminated a lens, dust or vapour.
Loewe Articos 55... | Answered on Feb 11, 2011
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Loewe Articos 55... | Answered on Dec 15, 2010
rans run when needed-not to worry, the only part of the set that gets hot is the lamp area
Loewe Articos 55... | Answered on Jul 29, 2010
the lamp will fail intermittently and light for 1-5 min, replace the lamp and it will run fine, note the ballest rarely fail
replace the color wheel and remove the fan blowing on the engine, its forceing dust into the wheel area, the wheel will last about 14-18 months, removeing the fan will extended life 2-4 years, there will be no heat issues with the fan removed, some models or later production runs will not have this fan
You have to replace Lamp before resetting Lamp Timer and most of all the ones I have replace TV does it Automatically.But if you do have a problem on Menu go to Lamp Timer and reset.
Loewe Articos 55... | Answered on Jun 30, 2010
I had the same problem with mine a while back. They changes out the lamp balast and it fixed it right up.
Loewe Articos 55... | Answered on Jan 15, 2010
had same problem, solved by lamp replacement. back to full glory!
jurgen
Loewe Articos 55... | Answered on Nov 21, 2009
You might have defective Fan if Fan stops running Lamp will not Light also keep in mind Ballast board it what turns lamp on and Fan is what keeps Lamp cool, and most of the time if set is not comming on Lamp is Bad. Call Encompass Parts 1-800-638-3228 or UED 1-800-648-6657 main 3 parts to DLP is Lamp,Ballast board ,Lamp Fan.Id say you have Bad Lamp! God Bless and hve a wonderfull Day.
Loewe Articos 55... | Answered on Nov 14, 2009
Try lowering Brightness first.Not contrast leave it up middle range.
Loewe Articos 55 55" Rear Projection Television Logo
57 questions posted
Top Loewe Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Loewe Televison & Video
Most Popular Question
vary noisey colour wheel
  • Televison & Video
