20 Most Recent Hipstreet Titan 7 Inch Tablet With 16gb Memory Questions & Answers
How to bypass the lock screen
Bypass Android Pattern Lockscreen using CMD No Root No Third party App or TUTORIAL ByPass Pattern there isn't an easy option, the above should help, good luck
8/7/2014 10:28:59 PM • Hipstreet Titan... • Answered on Aug 07, 2014
Hipstreet Flare 2 Frozen on startup scree that says "@9"
If you cant get in on recovery mode there is little you can do - its hosed. Take out any sdcard that may be in it and do a pin reset using the reset hole in the back of the tablet.
6/25/2016 12:17:52 AM • Hipstreet... • Answered on Jun 25, 2016
Screen messages
you might have played with settings apply default setting or else go to security and reset to factory setting but prior to this restore your data and account
9/15/2014 11:55:54 PM • Hipstreet... • Answered on Sep 15, 2014
Tablet
Setup android in recovery mode and select load from adb. You need to install the Android debug bridge toolkit SDK on the pc and have the right drivers for the tablet. You may also have to alter the android ini file in your profile to match the dev id in system device manager. Its not an easy thing to do especially on chinese no name tablets. Then issue the command Adb sideload "filename.zip"
5/13/2014 1:56:34 PM • Hipstreet... • Answered on May 13, 2014
Hipstreet Flare2 Frozen, How can I fix?
Frozen Screen Syndrome? Try holding the on/off button, while at the same time pressing Volume+. I've posted this solution for a number of tablets and it seems to have worked for most tablets! LindaSView
4/24/2014 6:54:48 PM • Hipstreet... • Answered on Apr 24, 2014
0answers
0answers
BROKEN SCREEN
Be the first to answer 1/6/2014 3:51:13 AM • Hipstreet... • Posted on Jan 06, 2014Be the first to answer
0answers
Hipstreet flare 2
Be the first to answer 11/15/2013 9:34:38 PM • Hipstreet... • Posted on Nov 15, 2013Be the first to answer
How do i return a tablet for fixing
Try contacting the manufacturer and/or the place where you purchased the tablet.
11/12/2013 4:42:12 PM • Hipstreet... • Answered on Nov 12, 2013
2answers
How to install rom on Onn 100011886 tablet go edition.
"rom"? What exactly are you trying to do? Are you referring to ROM as part of the tablet's memory? If yes, you probably will not be able to do it. ROM is a memory chip built onto the circuit board itself inside the tablet. You would need to completely dismantle the tablet to do it. Most tablets are not built to be taken apart for repairs.
4/13/2024 11:56:23 PM • Tablets &... • Answered 2 days ago
Hipstreet Titan 7 Inch Tablet With 16gb Memory Logo
3 questions posted
Top Hipstreet Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Hipstreet Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Hipstreet Tablets & eReaders
Most Popular Question
bypass lock screen
  • Tablets & eReaders
