20 Most Recent
JVC KD-LH810 CD Player Questions & Answers
My KD-LH810 turns on and
Sorry can't fix ur problem other then what the other. guy said . but maybe u can help me? I have the same stereo and need 2 know the wire plug wire colors in order across. top and. bottom row starting on top row left corner to right then bottom ?? Srry and thanks
My KD-LH810 turns on and plays the cd that is in
wipe the connection where the face connects at i had the same problem and it works fine after cleaning the connection and i will guess the power light itself is still lights up and no other button lights or the screen itself if that is correct then u most likely just have moisture in the connections try wiping it with a dry soft cloth
Connecting iPod to JVC KD-LH810!?!
Hi, KD-LH810 has no option for external input. Refer to the picture attached. It is only front and rear line outputs. Don't get disappointed. Buy the accessory cable KS-U100 and you are set. This info is from the installation manual.
Will not play cds
Hi.
If it does not read any disk, then the most common fault is lens problem.
You can read an article on the matter using the link below. It also applies to your in-car JVC system:
My player does not read disks.
Regards
Will turn on but no sound
check your speaker wires and speakers for shorts to ground. you can try disconnecting one speaker at a time. if no shorts or bad speakers, you may have a bad output ic.
