20 Most Recent
JVC KD-G210 CD Player Questions & Answers
Why panel buttoms not working?
If you are stating none of the buttons are working on your face, i would recommend a reset which is located behind the face. If still no operation, then it sound that you will need a new faceplate
Why car cd player panel not working?
Are you receiving power? Press the eject to see if you hear motorized noise. We would recommend a reset but if there are no noises or lights, please check fuse on back of radio and car to see if they blew. Otherwise, this might be a service issue on unit itself.
Clock setting
Hold the SEL button down for more than 3 seconds. A sub menu appears. Use the track select arrow key to select the hours, rotate the volume knob to correct hour. Press track select key to select minutes, rotate volume to appropriate minute. press select again to finish. If this doesn't help, go to jvc.com, then go to support, then user manuals, enter model number. You can dowload the entire manual for free.
Good luck
