20 Most Recent JVC KD-SX770 CD Player Questions & Answers
manual
0answers
I cannot tune the radio
The only thing I could find in the manual that might possibly solve this problem, is a "reset".
From the manual:
Press the reset button on the
panel holder. (The clock setting
and preset stations stored in
memory are erased.) (See page
2.)
You can get a copy of the manual here. I hope this helps and good luck. Please rate my reply - thanks.
7/12/2011 1:44:44 PM • JVC KD-SX770 CD... • Answered on Jul 12, 2011
0answers
I NEED TO CLOCK SET
Please go to the link below page 20 will tell you how to set the clock.
http://resources.jvc.com/Resources/00/00/98/GET0019-001A.pdf
4/2/2011 7:47:06 PM • JVC KD-SX770 CD... • Answered on Apr 02, 2011
I don't know how to set the clock
If you follow this link it will take you to clock settings on page 20. It will be easier than me trying to send it all here. May be an idea to print the whole manual off really?
Good luck with it and please feel free to remark if suitable.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/257/257KDSX870.PDF
3/29/2011 12:53:56 AM • JVC KD-SX770 CD... • Answered on Mar 29, 2011
CD Player does not work. Can CD player be
If it is possible to repair only habria that to check it to repair the fault in general always checks what is the module of CD or the lens
2/3/2011 1:44:10 AM • JVC KD-SX770 CD... • Answered on Feb 03, 2011
I just purchased front speakers
front left negitive, white with black stripe front left positive, white
front right negitive, grey with black stripe front right positive, grey
I hope this has helped you and please dont forget to rate my solution.
cheers
1/15/2011 9:30:57 AM • JVC KD-SX770 CD... • Answered on Jan 15, 2011
0answers
2answers
Jvc kd-sx770 car stereo--radio works, but cd player doesn't
Hello beeswing70,
The player is recognizing that a CD has been inserted but is not able to read it.
Sometimes the lens assembly becomes contaminated and obscures the laser. I'd try using a commercial "lens cleaning CD" two or three times and then try a CD again. These lens cleaning CD's are widely available. If cleaning does not help, the player need professional service.
Hope this helps.
8/21/2010 8:48:30 PM • JVC KD-SX770 CD... • Answered on Aug 21, 2010
Need help setting time on jvc kd-sx770
turn off the stereo then ull see the time only on ur set then u can set up!
3/14/2010 11:24:28 PM • JVC KD-SX770 CD... • Answered on Mar 14, 2010
How do you remove an upside down cd from a car
1...Try and tease it out by using an old CD through the slot
2..If that doesn`t work then the player will have to be removed from the dashboard, the metal cover taken off and the CD extracted.
Make sure you have the security code BEFORE you pull out the player from the dashboard.
If you do not have the code
POST ANOTHER QUESTION quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
Also quote the MAKE of CAR
10/18/2009 10:00:14 PM • JVC KD-SX770 CD... • Answered on Oct 18, 2009
Dosent play burnt cds
Try to burn cd in 4x speed burn. Or try to burn the audio as CDDA format at lower speed burn.
Crackes usually appears when burn the cd at high speed.
Pls. leave a comment
4/10/2009 6:49:01 AM • JVC KD-SX770 CD... • Answered on Apr 10, 2009
No audio output from jvc cd receiver kd-sx770
The internal amplifier is at fault.
This will need to be repaired by a electronics repairman.
There is no end-user fix.
You may choose to, instead, use the RCA low level outputs and install a dedicated amplifier to power your speakers.
Verify the fuses on the radio are good, and that there is not a blown speaker causing the internal amplifier to shut down.
Thanks for using FixYa - a FixYa rating is appreciated!!
2/20/2009 5:58:10 PM • JVC KD-SX770 CD... • Answered on Feb 20, 2009
3answers
JVC KD-SX770
Per manual, you can lock a cd in by pressing and holding the power and cd button for moer than 2 secondsthe cd cannot be ejected. if acd is inserted upside down, please -eject appears.
2/15/2009 8:59:36 PM • JVC KD-SX770 CD... • Answered on Feb 15, 2009
Headunit power problems
Hello dobbyville11,
It might be a few things but here is what i would check 1st, pull out the head unit make sure all the wires are pushed in all the way. The second thing i would suggest is checking the connection to the battery and ensure that the ternimals are clean and a good connection is available.
If there is something else it might be that you hold down a button while it starts, I know of some headunits that need this.
Please post what you do and how you did it. I look forward to your post.
11/13/2008 3:00:55 AM • JVC KD-SX770 CD... • Answered on Nov 13, 2008
Kd-sx770
You can buy it from pacparts.com
12/8/2007 5:02:45 PM • JVC KD-SX770 CD... • Answered on Dec 08, 2007
JVC KD-SX770 CD Player Logo
22 questions posted
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Car Audio & Video
Most Popular Question
need clock set
  • Car Audio & Video
