20 Most Recent JVC AM FM CD DET FACE CAR STEREO Questions & Answers
Make sure the red wire is still connected or make sure the red wire hasn't been severed. Also, check the fuses located in the engine compartment. The red wire connects accessory terminal in the fuse block. Also check the fuses in the cabin. This fuse box is typically located on the driver's side, at knee level, next to the door panel, and underneath the dashboard. As a last resort, the unit can be taken to an authorized or factory service center.
JVC AM FM CD DET... | Answered on Sep 11, 2019
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
JVC AM FM CD DET... | Answered on Aug 14, 2019
your accessory power for the radio is on the wrong circuit,wish the red wire of the radio
JVC AM FM CD DET... | Answered on Jun 16, 2019
try disconnecting power to the radio for a while. you can do that by disconnecting the battery.
JVC AM FM CD DET... | Answered on Mar 31, 2019
Didn't the deck come with the mounting kit and instructions? Usually they even give to a cut-out template. Please contact JVC and ask for the installation paperwork. You might consider taking it and your car to a stereo installation shop to have it professionally installed.
JVC AM FM CD DET... | Answered on Mar 03, 2019
You're stuck in DEMO mode. When you see stereo's on display at a store it is set to a DEMO mode that cycles through colors, functions, etc so that potential customers can see the different aspects of the unit. To get it to stop changing colors you'll have to go into the menu and turn DEMO OFF.
JVC AM FM CD DET... | Answered on Feb 19, 2019
Did you ever find a fix for this? This is happening to me as well...thanks!
JVC AM FM CD DET... | Answered on Jan 18, 2019
Try this, tune to the desired radio station and holdpress the station number ( 1-6) for a while, it should blink twice to confirm its storage.
Ekamave
JVC AM FM CD DET... | Answered on Dec 12, 2018
here is the manual it would help to install your device
http://www.jvc.com.au/JVCstores/PRODUCTS/357/ATTRFILE_File3/KD-G245-396%20Inst.pdf
Ifthis solution helpful/useful for you please rate the solution. THANKS FOR USINGFIXYA.
JVC AM FM CD DET... | Answered on Oct 06, 2018
This answer is found on page 16 of manual. goto BT mode and Press and hold [MENU]. Select
[BLUETOOTH]->
[DELETE PAIR]->[PHONE NAME]-> [DELETE YES]->DELETED!
JVC AM FM CD DET... | Answered on May 07, 2018
I suggest you ensure the ground is made to a sensible ground point and the supplies are also good and the antenna is also properly grounded and then monitor the supply voltage and the current consumed by the radio until it begins to distort. If the voltage and current remain steady the fault is either local interference or inside the radio, probably in the tuner.
If the current climbs and the voltage remains steady the fault is likely in the audio section...
JVC AM FM CD DET... | Answered on Nov 18, 2017
Setting the clock
  • Press and hold SEL (select) for more than 2 seconds. "DEMO", "CLOCK H", "CLOCK M", "DIMMER", or "AMP GAIN" appears on the display.
  • Set the hour.
  • 1. Select "CLOCK H" (hour) if not shown on the display.
  • Set the minute.
  • 1. Select "CLOCK M" (minute).
  • 2. Adjust the minute. Using the Control Knob
  • Finish the setting. To check the current clock time or change the display mode.
  • Press DISP (display) repeatedly. Each time you press the button, the display changes as follows:
  • • During tuner operation:
  • • During CD operation:
  • • During power off:
  • The power turns on and the clock time is shown for 5 seconds, then the power turns off.
JVC AM FM CD DET... | Answered on Aug 30, 2017
Contact JVC customer service please.
JVC AM FM CD DET... | Answered on Jun 27, 2017
Follow the instructions in the first column of the first page of the manual.
JVC AM FM CD DET... | Answered on Apr 24, 2017
Did you verify it has 12 volts on it's main power wire? Make sure the ground connection is good?
JVC AM FM CD DET... | Answered on Jul 03, 2016
JVC AM FM CD DET FACE CAR STEREO Logo
916 questions posted
Popular Products
Top JVC Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Car Audio & Video
Most Popular Question
2010 vw cc factory stereo amp popping
  • Car Audio & Video
