20 Most Recent
JVC KD-S640 CD Player Questions & Answers
JVC KD-S640 pinout needed
For ten bucks, you can buy a new connector:
http://www.jvcservice.com/store/ProductDetail.asp?part=JV16-0001A
To figure out how to wire it:
http://books.jvcservice.com/download/256614688/28879.pdf
Page 25 describes the color of the wiring in the harness.
Ooood ao on display screen
you probably already solved your problem by now, or you probably have a different stereo, but in case you haven't let me tell you what I just did. you just have to reset you system, to do that you take off the front part and stick a pen in the reset hole. The reset hole is in the lower right corner.
CD's are being ejected without
Take a torch and see if there are any foreign objects in the loading compartment. Children are know to insert for coins to just about anything they can squeeze through the ****.
Then try removing the system from the dash and open the top lid. see if you can clean the lens from a small cutout on the loading mechanism using a cotton ear bud. Do it in good light because the lens ( looks like a fish eye ) can oly been seen at an angle through the cutout.
My jvc player rejects my
The mechanism that controls opening and closing of the tray is bad, that is why it keeps ejecting cds when inserted in.
Unplug the player and unscrew it open then plug it after opening the cover and try to insert a disc and see the how far the cd goes before ejecting, be sure not to touch any metal part in the player to avoid shock.
After trying to play a cd, you will notice where the tray ejects the cds from, it is located try to unplug the player and disassemble the mechanism, you will see either a worn out rubber or teeth on the mechanism, then replace them and reassemble it back together, after doing that, the player will be able to hold a cd.
Take care and good luck
Cd's won't play
Its dirty, try a disc cleaner, (brushes not solution) and if that does not work, its time to replace, (unless the radio is all ya want).
ALSO- if you are trying to play burnt discs, (cd-r, mp3 discs etc) than that could be the issue as not all indash cd players support non store bought cds
I want to wire the kd-s640 to my boat. I need to
Usually it's....
black = ground
red = switched battery power
yellow = constant batery power (for clock...etc)
orange = illumination
blue = amplifier turn on or accessory (electric antenna, amps etc)
green/white/purple/grey are speaker wires.
Control Panel Replacement for KD-S640
Here is the DIRECT link to buy the parts you need. Copy and paste this link to your browser.
http://www.pacparts.com/model.cfm?CFID=1284915&CFTOKEN=48698629&mfg=JVC&model_id=KDS640&row_start=1&src_model_id=KD-S640&action=list_part
Rejecting cd's
Press the Q/I/ATT and the "sel" button at the same time with the unit off for more than 2 seconds. This will reset the entire unit (you'll have to re-program the memory stations for FM & AM). The disc should eject automatically.
Hope that helps!
How do I change the time on the clock??
hit the power button. wait till it says ATT or something like that then hold select then use the volume to change time and up/down to change Minute.Hour.
i had this same problem
Error 10 message on display screen
Same issue but pressing Power and SEL would not reset unit. Found solution. Once again disconnected the car battery. Removed the face unit from the radio base and then reconnected the battery. Replacing the face unit AFTER the power was re-established solved the issue. (Probably pulling the radio fuse rather than toying with the battery connection would have done the same thing.)
