20 Most Recent
JVC KD-S580 CD Player Questions & Answers
Is there a mute button
There should be a button labeled ATT. ATT is short for attenuation, which is basically the same thing as mute.
How to set the time
You can download and print the instruction manual in PDF format by clicking this
link.
The detailed steps for seting the time is given on page 17 of this manual.
Adobe PDF Reader is required to view this manual.
Download Adobe Reader Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using
FixYa.
Trouble playing JVC KD-S580
i have the same problem in a 2001 mercury cougar. i got power all the way to the back of the radio from the ignition (red) and constant (yellow) wires and the ground wire is good. Think the head unit might be screwed the fuses are all fine. not sure though
How do you hook up a jvc kd-s580 to a 91 ford
Get a wiring plug kit. These are available at any Walmart. They are specific for your vehicle make and not the radio. Radio manufacturers typically use all of the same colors so this should be a matter of matching color to color straight forward. Double check this with yoru radio manufacturer schematic before applying power to the radio.
Here is the
wiring diagram for your truck
Where does the remost wire go ?
Remote wire is wires to an amplifier.
It produces a 5v signal so your amplifier turns on.
If you do not have an amplifier - the wire is not used.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
No sound from speakers. Stopped working about a
This could happen when your speaker wires are touching the body of the car near the place where you connect them to the body.
If so, try using some wooden spacers to avoid contact with the car body
