20 Most Recent
Dymo Pocket InkJet Printer Questions & Answers
How do I switch between
click on file and chose the print preview open the setting and convert the horizontal to vertical
I lost the intruction booklet - how do i change
You have not mentioned the DYMO Model #.
Click on the link below to open the DYMO Page to download the manual and use it.
Choose the DYMO model and choose the manual option to download.
Download LinkThank you for contacting FixYa
*Please rate this solution with thumbs up
Dymo 4XL Label Printer 10% of the time fails to print, says "Dymo 4XL is in an error state" and nothing happens.
If you're experiencing an "error state" with your Dymo 4XL Label Printer, there are a few steps you can take to troubleshoot and resolve the issue:
- Check the connections: Ensure that the USB cable connecting the printer to your computer is securely plugged in on both ends. If using a USB hub, try connecting the printer directly to a USB port on your computer.
- Restart the printer and computer: Power off the printer and disconnect it from the power source. Restart your computer as well. After a few moments, reconnect the printer to the power source and turn it on. Wait for it to initialize.
- Update the printer driver: Visit the Dymo website and check for any available driver updates for your specific printer model. Download and install the latest driver software for optimal compatibility.
- Clear any print jobs: Open the print queue on your computer and ensure there are no pending print jobs for the Dymo 4XL. If there are any, cancel or remove them.
- Verify correct label settings: Double-check that you have selected the correct label size and settings in your printing application or software. Ensure that the label size matches the labels you are using.
- Check for obstructions or label jams: Open the printer and inspect for any obstructions or label jams that could be causing the error. Remove any stuck labels or debris, if present.
- Reset the printer: Locate the small pinhole on the back or bottom of the printer. Insert a paperclip or similar object into the pinhole and press the reset button inside for a few seconds. This will reset the printer to its default settings.
- Contact customer support: If the issue persists, it's advisable to reach out to Dymo customer support or consult the printer's user manual for further assistance. They may have additional troubleshooting steps or provide guidance specific to your situation.
How do I reset my Dymo LabelPOINT 350 Printer
To reset your Dymo LabelPOINT 350 Printer, please follow these steps:
1. Disconnect the power cord from the wall outlet and then disconnect the power cord from the back of the printer.
2. Press and hold down the 'Function' key.
3. While still holding down the 'Function' key, reconnect the power cord to the back of the printer.
4. Release the 'Function' key after the printer starts up.
5. Disconnect the printer from the power cord once more.
6. Reconnect the power cord to the wall outlet and then reconnect the power cord to the back of the printer.
7. Your Dymo LabelPOINT 350 Printer should now be reset.
How can I cancel printing on my dymo?
If you are printing from a computer, the print job will be in the bottom right taskbar (click the small arrow). Open the icon and in the heading Cancel Print Jobs.
Or you can go to Start - Settings - Devices - Printers and Scanners and choose the printer and cancel from there.
Dymo LetraTag letters won’t work
I also had a problem with the middle letters not working. I opened up the machine and cleaned the circuit board and the bottom of the keypad with rubbing alcohol. That seemed to do the trick.
