20 Most Recent Loewe Aconda ACO9303 30" TV Questions & Answers
Common problem with this model is the line output transformer.
Loewe Aconda... | Answered on Jan 14, 2014
Prueba descargarlo de aqui:
http://www.opweb.de/manufacturer.php?manufacturer=Loewe
Suerte
Loewe Aconda... | Answered on Jul 29, 2013
Have a search over this link
Manual for tv
Loewe Aconda... | Answered on Nov 20, 2012
The Loewe have only a few problems---this is not one of them---disconnect it and a cable or sat box if used from power for while and try again----its getting harder to find shops who will work on these at parts are scarce and expensive (remote wholesales for 85 dollars--I have 2 extra ones).
Very expensive set when new but if not something easy maybe let it go......
Loewe Aconda... | Answered on Nov 04, 2012
There is in the following site. it costs $15.99 in PDF format.
http://www.manuals-in-pdf.com/PLANUS%204672Z-p-281571.html
Loewe Aconda... | Answered on Oct 25, 2012
My Loewe did the same thing tonight. The picture went blank and the rered and green light came on together. Any suggestions?
yes but you have to open the tv
Loewe Aconda... | Answered on Jan 31, 2012
I repaired a lot of these sets when they were new and under warranty.
The most likely reason for 'shutdown" which is what you are describing, is one of two parts.
The "Flyback" or High voltage transformer in these sets fails; usually with back off when you try to turn set on you see a little arc at top of high voltage transformer---means it is bad-----so common I have literally replaced dozens of them.
The second common (not as common as the transformer) reason is there are a number of special capacitors right around the same area as the transformer; they do not short or burn---they open like the filament in a old style light bulb----a little tricky to find but not expensive.
The Flyback transformer is black with a large red wire coming out of the top that goes into the picture tube; part may be found on internet for approx 50 dollars or Loewe parts center for 75 plus.
Everything about these sets was expensive; I still have 3 brand new remotes for them--wholesale on them about 85 dollars.
SD TECH
Loewe Aconda... | Answered on May 13, 2011
Power Supply board needs replacement or require component level repair by an expert.
Thanks
Loewe Aconda... | Answered on May 12, 2011
I know a lot about these sets---I did warranty work on them when they were new and later---Set was designed in Germany and the company based in England---for a while the parts were very hard to get---but the last time I fixed one there was a Parts center here in the USA.
Set is basically modular in design--meaning if the problem cannot be traced down and found you can buy from the USA SOURCE a replacement board.
Answer a few questions and I will try to help you.
1.) Before the set failed did the picture fill the entire screen from right to left and top to bottom?
2.) When it shuts off does the power light stay green or go to red? (standby).
3.) Does the set make any unusual sound or have a burning smell?
THERE IS ONE VERY COMMON PROBLEM ON THIS SET--THERE ARE ABOUT 8 CERAMIC CAPS ON THE "MAIN" board----One of them opens (does not short!)
This cap is almost in the middle of a group of brown caps (the larger ones never fail--it is fairly small) I think I still have some new ones here--if you need I can look for them and tell you what markings id the cap you are looking for.
Someone has to unsolder each cap from the board and check them with a cap meter---if they find one open---this is the problem.
Regards, SD TECH
Loewe Aconda... | Answered on Jan 30, 2011
Hi
Does the unit power up ok or revert into standby? or are both green and red lights on, on the control button?, this tv has common problems with the power supply failing and there is a repair kit available.
regards
TechSupp12
Loewe Aconda... | Answered on Dec 11, 2010
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Loewe Aconda... | Answered on Dec 09, 2010
Hello
Your TVs video output transistor [Red] has got shorted. Usually a transistors are used in most of the colour telivisions in video output stage.. If it is a transistorised video output stage, replacing red output transistor will solve the problem. In some modern sets there are so many types of Integrated Circuts [ICs] are used. If your TV uses Ic as video output, replace the Ic.
Loewe Aconda... | Answered on Oct 17, 2010
Hi
Thanks for using FixYa. It seems to be a horizontal/vertical circuit issue. You’ll need to open the back of the unit and check/test HOT (horizontal output transformer) and flyback, replace the part that has gone bad.
This is only recommended if you have electrical expertise.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Loewe Aconda... | Answered on Jun 28, 2010
Ur tv power supply board is dead.Replaced the power supply board will fix this and get ur power back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Loewe Aconda... | Answered on May 09, 2010
Its Flyback lines caused by the G2 voltage being to high.check the voltage it should be around 520 volts
Loewe Aconda... | Answered on Apr 13, 2010
Loewe Aconda ACO9303 30" TV Logo
70 questions posted
Top Loewe Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Loewe Televison & Video
Most Popular Question
not sure problem exactly same
  • Televison & Video
