20 Most Recent Loewe Aconda ACO9383 38" TV Questions & Answers
Pin-cushion distortion. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Loewe Aconda... | Answered on Sep 14, 2015
Nobody in US do know to repair this TV.
I've read on your site where a number of others have had this problem and on the strength of that have talked to a local technician who has more or less agreed - so will go with his expertise. Many thanks for your interest.
Loewe Aconda... | Answered on Jul 22, 2015
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
Loewe Aconda... | Answered on Aug 05, 2012
Hello Tom Helton,
Welcome, and thank you for using FixYa!
To answer your question: A television Professional will need to run through the gambit of tests on this television with a Volt-Meter and Osilliscope. Each resistor, transistor, capacitor, and soldier joint will have to be checked for failures.This is the only way to ensure if the television is salvageable. But it will cost at least $150 for diagnostics, then add on parts, and lastly, the repair labor cost. You could be looking at between $250.00 and $350.00 for the repair costs.I wish you the best with your decision between repair or replacement.
Have a great day!
Loewe Aconda... | Answered on Dec 03, 2011
Thanks for using Fixya.com
The problem with your tv is with the transformer, many times this could be a bad electrolytic capacitor that has blown out. Many shops can Fix a transformer issue well under $200 bucks.
This is a wonderful TV , I would suggest you get the part first then take the tv with the part so the price would be a whole lot less, You do not want to pay brokers fee's if you know what I mean.
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Loewe Aconda... | Answered on Aug 01, 2011
I know these sets, did a lot of work on them when new and under extended warranty.
Two common problems:
With the back off look at the black transformer to the right with a big red wire that goes up to the bell of the picture tube: lots of these will arc at the top left side of the part--if you turn the set on and see a brief spark there the Flyback transformer is bad.
These are quite affordable and fairly easy to replace.
The second problem they have is there are about a dozen brown caps in front of the Flyback and one of them "opens" not a short but if it opens voltage etc go up and set shuts down.
8 out of ten times it is the Flyback.
Look closely at the white label on the left side of the flyback--the part number is there!
If this told you something you did not know rate this solution as very helpful as I do this here for free.
I have not seen many of these sets lately but still have the 3 new remotes my shop gave me.
SD TECH
Loewe Aconda... | Answered on May 10, 2011
HOW TO ENTER THE SERVICE MODE LOEWE ACCONDA 9381
Loewe Aconda... | Answered on Apr 02, 2011
Before we start taking things apart, lets try your simple remove power plug routine and power system back up. Also, please try your unit on a few different channels to see if your problem continues on each channel. Your Main Board, Power Board, T-Control Board are suspected problems at this time. Press and hold the power button for about 15 seconds, the unit should power down by itself after you have powered it on. If it does not, then do not be concerned. Let me know if the problem continues. The first link below will bring you directly to the troubleshooting guide if you need to continue forward with the same error. Additional information http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com
Loewe Aconda... | Answered on Jan 19, 2011
http://www.manuals-in-pdf.com/index.php?main_page=product_info&products_id=125663
Above is your service manual.
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed, and it will stop for good, as in how tour set has acted. . Sometimes this is called a "Hic-upping set".
Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Loewe in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
Loewe Aconda... | Answered on Dec 18, 2010
Hello
The problem either the on/off button is faulty or a heat sink not doing it's job.
The on/off button simply toggles a low voltage circuit that powers your tv. If it is dusty, it may complete the electrical circuit and send a false signal.
A heat sink may be dusty and unable to dissipate heat. Overtemp protection may be switching the TV off.
what you should do is to get a can of compressed air, open the back of your tv and clean the dust off the circuit boards.
Loewe Aconda... | Answered on Dec 13, 2010
I worked in a shop that fixed these sets and tried many universal remotes and not one worked. The remotes from the parts depot in the new york area are very expensive----about 80 dollars wholesale.
You will find some on EBAY from time to time. When we stopped fixing these sets I got two brand new ones which I have in my collection. I would if you search EBAY you may find one.
typical part numbers are like: 87000-066 etc.
I have attached a photo of what they look like. There are minor differences but any of them should work your set fine.
SD TECH
Loewe Aconda... | Answered on May 09, 2010
Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is, it starting up, detecting a fault condition and shutting down, over and over. You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Loewe Aconda... | Answered on Apr 27, 2010
QUITE LIKELY THE FLYBACK TRANSFORMER
Loewe Aconda... | Answered on Jan 08, 2010
Televison & Video Logo
32 questions posted
Top Loewe Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Loewe Televison & Video
Most Popular Question
ve got loewe aconda 9381 zw switching
  • Televison & Video
