20 Most Recent Diesel Ertl 116 John Deere 4620 Diesel Tractor W/ Duals Questions & Answers
2answers
Cant turn off diesel engine with ign switch 2016 massey ferguson gc1710
https://www.youtube.com/watch?v=m1KyGZR-v5Qhttps://www.youtube.com/watch?v=m1KyGZR-v5Q
4/17/2020 1:02:10 PM • Diesel Toys • Answered on Apr 17, 2020
I'm shopping for a diesel fuel line that goes from the fuel housing to the injector pump. (165 Massey Ferguson).
go to a diesel specialist shop with the old one as a sample and you will get one gp to a tractor servicr agent to get one if it is plastic , then it is a special fuel resistant plastic hose
3/21/2018 11:14:57 PM • Diesel Toys • Answered on Mar 21, 2018
Type of engine oil for a Massey Ferguson 1230 . Diesel engine.
it will be in the owners manual or available from the service dealer may be shell diesel rotella 20w-40 would be ok
3/5/2017 1:39:17 AM • Diesel Toys • Answered on Mar 05, 2017
0answers
My man diesel TGA 18.350. it shows me on the dashboard coads 01080_5 and 03076_9 and 03792_5 please i sent my questions but i did not get an answer please i need help
difficulty in find a web page that has the codes properly explained one site I found ---techtransa.It has a list or the numbers before the under score and what the fault areas are To get there I went google and typed in--mandiesel model tga-18-350 fault codes-- there are other pages that make reference to fault codes but are not specific to your model reading around the fault codes are specific to man and it seems that a normal obd-11 scanner will not be accurate you might have time to down load a good site when you find one , but as I consider a heavy vehicle should be out earning income , time off the road costs money so, in the mean time and until you can find a down load for the faults, maybe you should take it to a service dealer and have it fixed possible even to get a copy of the codes from the technician
7/20/2016 7:45:56 AM • Diesel Toys • Answered on Jul 20, 2016
0answers
Torque settings
Be the first to answer 6/20/2016 12:18:45 PM • Diesel Toys • Posted on Jun 20, 2016Be the first to answer
What would be causing my MF65 to blow diesel out of the dipstick?
If your machine is truly spraying fuel oil out of the dipstick tube, you most likely have some severe engine damage, most likely originating from a leaky (dripping) fuel injector/nozzle. The fact that fuel oil is present in the crankcase leads me to believe that at least one cylinder has been overfueling, causing wash-down of the cylinder walls and resultant piston ring and cylinder wall (or liner) damage. Enough raw fuel is getting (first) into the cylinder and (second) into the crankcase to wash the normal oil film off the cylinder walls, resulting in excessive ring and cylinder wear. In all likelihood, you now have excessive crankcase pressure due to the damaged rings and cylinder walls, as compression pressure is being lost into the crankcase.. Have this engine evaluated by a professional, as a tear-down and rebuild is very likely necessary. At the very least, the fuel system -- injectors/nozzles specifically -- must be investigated and repaired...
5/5/2016 2:06:28 PM • Diesel Toys • Answered on May 05, 2016
How can I fix a diesel leak on a Massey Ferguson 250?
2/13/2016 11:07:52 PM • Diesel Toys • Answered on Feb 13, 2016
255 massey ferguson tractor diesel empties into oil pan when tractor sits diesel tank goes empty oil level goes over the hi level just about to the top of the stick.where would you look first?
my 135 fuel supply pump was leaking into the engine . I removed the pump pressured a line with air and found the leak at the seal
2/6/2016 12:30:57 AM • Diesel Toys • Answered on Feb 06, 2016
How do I remove the broken end of the tach drive recessed into the end of the camshaft on my massey ferguson 65 diesel
Hi Bill: Here's a trick you might try. It should work if the broken part is not physically attached and if it is magnetic. Find a short piece of plastic tube, even a drinking straw will do, that will slide into the hole. Find a common nail that will just slide into the tube. Grind the pointed end off the nail so it is flat. Slide the plastic tube over the nail also that it bumps into the head, then cut the tube off flush with the flat end. Slide the tube with the nail in it into the hole in the end of the crankshaft. Take your handy super magnet and touch it to the head of the nail. If you are lucky, if you gently pull the nail/tube out with the magnet attached, the broken but will come out. Hope this helps.
2/6/2016 12:27:19 AM • Diesel Toys • Answered on Feb 06, 2016
WHERE CAN I FIND INFORMATION FOR A YEAR OF A MASSEY FERGUSON MF 40 WITH A SERIAL NUMBER 9A 277334. THE HOOD IS STICKERED WITH MF 40. IT HAS A 4 CYLINDER DIESEL IN IT. THANK YOU.
this tractor was produced in the years 1972 to 1977 and production was finally stopped due to it not having roll over protection , although many were retro fitted with a hoop later last years of production so depending if you have a hoop over the operator seat or not would narrow down your production date
11/13/2015 1:15:07 AM • Diesel Toys • Answered on Nov 13, 2015
2answers
Do you have any good craft ideas for kids under six?
I was able to find you this website with all kinds of great craft kits for pre-kindergarteners.
3/26/2024 11:30:29 AM • Toys • Answered on Mar 26, 2024
Hi I've got a babyweaver
Sounds like you are missing the central support rod or bar that connects the Babyweaver swinging crib to the stand, providing stability and support for the crib. This component is crucial for maintaining the structural integrity of the crib and ensuring safe usage. Here are some steps you can take to address the missing part: 1. Contact the Manufacturer: - Reach out to Babyweaver or the manufacturer of the swinging crib to inquire about obtaining a replacement central support rod. - Provide them with details about the missing part and the specific model of the swinging crib to ensure you receive the correct component. 2. Check for Spare Parts: - Check if the swinging crib came with a user manual or assembly instructions that may have information about spare parts or replacement components. - Look for any contact information provided for customer support or spare parts inquiries. 3. Online Search: - Conduct an online search using keywords such as "Babyweaver swinging crib central support rod" or "Babyweaver crib replacement parts" to see if you can find the specific part for purchase. - Explore baby product retailers, online marketplaces, and specialty stores that offer replacement parts for nursery furniture. 4. Local Retailers: - Visit local baby product stores or furniture stores that carry nursery items. - Bring the existing part (if you have one side of the support rod) to help them identify and match the missing component. 5. Custom Fabrication: - If you are unable to find a suitable replacement part, consider contacting a metal fabrication shop or a carpenter who may be able to custom-make a central support rod that fits your Babyweaver swinging crib. - Provide them with measurements and details about the required specifications for the part.
3/22/2024 3:29:32 AM • Toys • Answered on Mar 22, 2024
I have a new model teddy ruxpin and my 2 year old daughter tripped and dropped him. His lights all come on but his app and sound are not working
It sounds like the drop may have caused some internal damage to the electronics or wiring of the Teddy Ruxpin toy. Here are some steps you can take to try and troubleshoot the issue:
  1. Restart the Toy: Sometimes a simple restart can resolve minor issues. Try turning off the toy completely, including any power switches or buttons, and then turning it back on again after a few moments.
  2. Check Battery Compartment: Ensure that the batteries are properly inserted and making good contact with the terminals inside the battery compartment. If the drop caused any displacement of the batteries, it might affect the toy's functionality.
  3. Inspect for Physical Damage: Carefully examine the exterior of the toy for any signs of physical damage, such as cracks, dents, or loose parts. If there's visible damage, it may indicate internal damage as well.
  4. Test with Different Devices: If the Teddy Ruxpin toy connects to a separate app or device for sound playback, try connecting it to a different device to see if the issue persists. This can help determine if the problem lies with the toy or the connected device.
  5. Contact Customer Support: If none of the above steps resolve the issue, it's possible that the drop caused internal damage to the toy's electronics or wiring. In this case, you may need to contact the manufacturer's customer support for assistance. They may be able to provide further troubleshooting steps or offer a repair or replacement option.
Keep in mind that since the toy is relatively new, it may still be under warranty, which could cover repairs or replacements for damage caused by accidents like drops. Be sure to check the warranty information or contact the manufacturer for guidance on warranty coverage.
3/21/2024 2:25:15 PM • Toys • Answered on Mar 21, 2024
Diesel Ertl 116 John Deere 4620 Diesel Tractor W/ Duals Logo
1 questions posted
Top Diesel Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Diesel Toy Expert? Answer questions, earn points and help others
View Most Popular
Diesel Toys
  • Diesel Toys
Most Popular Question
shopping diesel fuel line goes from fuel
  • Toys
