20 Most Recent iLO 2600 Television Questions & Answers
sorry we can not
iLO 2600... | Answered on Oct 07, 2017
You would need a converter to make it work. Adapters won't work as the type of signal would need to be changes. Your best bet would be to purchase a DVD player that has outputs that work with the tv. Sorry.
iLO 2600... | Answered on Jul 07, 2016
Was going to watch movies off thumb drive been stuck there could t watch movie.
iLO 2600... | Answered on Apr 12, 2015
thats the old vga connector an the new Dvi
iLO 2600... | Answered on Oct 21, 2014
0281,0288.0285.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
iLO 2600... | Answered on Aug 11, 2014
Try using the code search (or similar) function to locate a code that will control some (but maybe not all) of the functions of your iLO TV.
iLO 2600... | Answered on Jun 12, 2014
I understand Ilo's are made by Tatung. You may try 0055 or 0003. I haven't confirmed this, but it's worth a try. http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
iLO 2600... | Answered on May 14, 2014
If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
iLO 2600... | Answered on Feb 25, 2014
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
iLO 2600... | Answered on Dec 29, 2013
If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, adn buy that one according to availability. If you wish to get more details about this, try the sites linked here. It has set-up code list, and set-up procedure to many popular brand universal remote controls.
http://electro-medical.blogspot.com/
iLO 2600... | Answered on Dec 24, 2013
All 46" flat screens are 16:9. Without the model number it is impossible to know what the resolution is.
iLO 2600... | Answered on Sep 11, 2013
Have to have full model number to know for sure.
Televison & Video Logo
393 questions posted
Popular Products
Top iLO Televison & Video Experts
Ekse
Jerry Greenberg
Jerry Greenberg
CoppellTVRepair.com
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • iLO Televison & Video
Most Popular Question
purchased ilo 26hd flat screen walmart
  • Televison & Video
