20 Most Recent Canon imageRunner C3100 Copier Questions & Answers
Hi Its fair simple, if you are scanning to windows PC, Create a folder called scans in your C:\ drive. Share it and give all the permissions. Thereafter log on to your copier using the IP address in your internet explorer. Go to address, click address book one, click the second tab on your left saying register new address. thereafter enter you name, then change from FTP to SMB and then host name will be your computer name\ip address, followed by scans(\\computername\scans)just like that. followed by your username and password.
Thanks
Canon... | Answered on Jul 03, 2015
I had a similar problem with my MF6540. I could access the remote UI and see that the printer was recieving information via the print log. It would list all of my test pages that I tried to print but in the print results column I would get an error code NG(##5536) and the printer would not actually print anything. I tried the UFRII driver stated above and everything seems to be working now.
Canon... | Answered on Nov 02, 2014
one side light
Canon... | Answered on Feb 20, 2014
Clear Admin Password Get Full Access
You need to get access to service mode settings which a printer technician should know then follow below instructions
>COPIER>FUNCTION>CLEAR>PWD-CLR
Headlight PWD-CLR and hit OK
Canon... | Answered on Oct 30, 2013
Hello skunkel,
Yes, I believe I can help you. Hopefully these previous admin person did not go nuts with the security thing. But I can help you either way. The least painful method. Approach the copier and view the operator control panel as we are going to go into service mode and delete the admin password. I am about to describe a "fluid 3 step keystroke " function which will put you into service mode. Before we start , locate the "ADDITIONAL FUNCTIONS" button located between the LCD screen and the 9 key pad. Now, press additional functions, then the numbers 2 and 8 simultaneously, then back to additional functions in a smooth three step flow. The screen will change as you have entered service mode. Depending on the configuration of the device you will have several tabs in your display and copier will be at the top. Press copier. A new display appears with several tabs across the top. Press the function tab. New display again, and now press "clear". New display again. Look for "PWD-CLR". Once found, press it. It will be highlited,and then press the "OK" button in the lower right corner. The ok button will indicate you have touched it by beeping or highlighting or both (depends on the model). Then turn the main power off (the actual switch not the button on the op panel. If you are in doubt unplug the machine. After a few seconds re-energize the copier. If the previous administrator merely used a password then it is now deleted and you are home free. If not, then you will need to enter service mode again.......copier........function.......clear..... and then find MMI . Clearing this field will delete ALL customer inputs(IP address, favorites etc). If it is necessary press MMI and then ok. Usually you wont have to do this. But if you do you can have the fun of re-entering all your old settings as it will go back to factory settings.
Canon... | Answered on Mar 28, 2013
Reader communication error
Check on connection between the reader controller
PCB and the main controller PCB, Check on the
reader power supply
This error can occure during transfer of machine, the boards are conected with one slot.Try to adjust and reconnect boards.
Canon... | Answered on Feb 24, 2013
Drum motor error
Check the connector and replace the motor
Canon... | Answered on Jan 19, 2013
91 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
canon imagerunner c3100 shows error code
  • Office Equipment & Supplies
