20 Most Recent
Canon FAX-L350 Plain Paper Laser Questions & Answers
Rec . paper jam
This means your rollers are either dirty or damaged. The same thing happened to my Lexmark printer and they told me to clean the rollers. Nothing happened it still was messed up so they just sent me a new one...
Change Date/Time on Canon Fax L350
Left the flap on the right hand side of the fax machine.
Select Data registration
use the down arrow
1. Data registration
SET
1. User Settings
SET
1. Date & Time
SET
Enter date or time
SET
The set document is stuck
Open the document/operation panel cover and look inside its underneath. there should be a black arm hanging down and it will be stuck in the up position. Free it off and that should cure it.
Canon Fax-L350
display check printer
Alarm red
"could
Open the main cover. Look into the body of the machine. The covers top left corner has a projection that when the lid is closed this projection passes through a hole in the main body and hits a micro switch to say the cover is closed. the switch has stuck. Poke a thin screwdriver (power off of course) and watch the switch pop back into its right position. All will be well. A well known fault of this model.
Change the dates on the
Lift the flap on the right-hand side of the fax machine.
use the down arrow
SET
1. User Settings
SET
1. Date & Time
SET
Enter date or time
SET
Good Luck!
Hope this helps!
CreativeTECH
Check cover/cart error message
fax toner catridge door is not properly closed. when you close that there is a micro switch that is not going to activate. Please be sure it is closed properly
HOW DO I CHANGE A SPEED DIAL NUMBER
1 Open panel cover
2 Press DATA REGISTRATION
3 Press V to display 2. TEL REGISTRATION
4 Press SET twice
5 Press ^ or v to find the number you want to change
6 Press SET twice
7 Enter new fax number
8 Press SET twice
9 If you don't want to change the name then enter SET once more. Otherwise enter the changed name using the number pad as if it were a mobile phone (2 = A, B, C etc)
10 To continue press DATA REGISTRATION
11 Repeat steps above for other numbers
12 To end press STOP
We have been a given a fax machine but we need to
if is a l350!open the cover over the one touch speed dails,press data registration and set!It says user settings,press set,Scroll to unit tel nr,press set,type in your nr,press set and there u go!
