20 Most Recent Canon CFX-L4000 Plain Paper Laser Fax Questions & Answers
2answers
How do I clear the memory on a Canon CFX-L4000 Fax
Press the dataregistration button,press set.Scroll until you find tx settings,press set.Scroll with the arrows untill you find (erase failed tx)
Press set and change it to on.All the memory of the failed tx reports will be cleared and the memory will be 100 percent available.
4/12/2016 8:08:18 AM • Canon CFX-L4000... • Answered on Apr 12, 2016
How do i delete memory
Lift the panel press data registration then press #. Press the down arrow to test and press set and set again. this will perform a memory test and wipe out the contents that hold the documents while leaving the speed dial memory.
9/20/2012 3:01:07 PM • Canon CFX-L4000... • Answered on Sep 20, 2012
How do I clear the memory in my Canon CFX-L4000
Hi function + memory reference (04) + set + star (astrix /*) keep repeating till display reads memory clear.
10/18/2011 2:23:01 AM • Canon CFX-L4000... • Answered on Oct 18, 2011
0answers
3answers
Error code ##322
that code is a fixing heater code, may need to replace fuser heat roller
7/12/2011 8:00:41 PM • Canon CFX-L4000... • Answered on Jul 12, 2011
Need to fax and get proof of receite that fax was
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON CFX-L4000.pdf
6/11/2011 4:42:04 PM • Canon CFX-L4000... • Answered on Jun 11, 2011
It is impossible to enter
Turn the printer off, unplug the cord from printer, take the cover off, you might need to remove 2 silver screws from the inside the top cover and 2 black plastic srews, you will see the white lever on back left rear with spring on it. This lever is stuck in the up position. You can manually turn this white clutch to make the white lever drop back where it belongs. This shoul help.
Thanks
Let me know if I can futher help.
6/9/2011 6:01:46 PM • Canon CFX-L4000... • Answered on Jun 09, 2011
Howdi all. Im another person
i only found the service manual http://www.givemefile.net/smanuals/_xerox_and_ifis/canon/file/33046.html
5/10/2011 5:23:32 PM • Canon CFX-L4000... • Answered on May 10, 2011
I need to know HOW TO GET A CURRENT PAGE COUNT.
To get the page count, press Function, then choose Data Registration, then #, then scroll down to Printer, press OK, scroll down to Page Count, press OK.
4/2/2011 7:36:32 PM • Canon CFX-L4000... • Answered on Apr 02, 2011
How to fax to mexico?
The country code for Mexico is 52. Add 52 in front of the phone number to send a fax to Mexico.
3/28/2011 4:48:13 PM • Canon CFX-L4000... • Answered on Mar 28, 2011
How do I get a
Press FUNCTION and DATA REGISTRATION.
Use the search buttons(^,v) to display 3. REPORT SETTINGS.
Press SET, then use the search buttons to display "TX REPORT"
Press SET, then use the search buttons to select "OUTPUT YES"
Press SET.
now exit from menu and whenever you send a fax a trasmission report will be generate automatically
1/6/2011 6:27:39 PM • Canon CFX-L4000... • Answered on Jan 06, 2011
How do I silence the
Look above the "stop" button there is little speaker drawn witht the ring volume values.Move it to the left to lower the power of the ringing.
10/20/2010 2:31:35 PM • Canon CFX-L4000... • Answered on Oct 20, 2010
Canon CFX-L4000 Plain Paper Laser Fax Logo
108 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
error code 322
  • Office Equipment & Supplies
