20 Most Recent Hitachi 51G500 51" Rear Projection HDTV-Ready Television Questions & Answers
Need to know how to go cable free. Have TERK digital antenna
Shouldn't do, just connect the antennas into the Belling-Lee TV antenna socket at rear of set, tune channels. If you antenna won't fit, you may need an "F" connector to "Belling-Lee" converter plug. You will need an "Ordinary" Yagi VHF/UHF antenna installed though. Is that what that digital one is?
6/2/2016 5:47:50 AM • Hitachi 51G500... • Answered on Jun 02, 2016
Television screen gradually went black
Is the power somehow getting switched off, or is the screen going black? Try consulting the troubleshooting section of your owner's manual.
11/19/2012 12:18:06 AM • Hitachi 51G500... • Answered on Nov 19, 2012
2answers
Is my tv digital already or do I need a converter?
Your TV does have a digital tuner in it already. Also a converter box is only needed if you use an Antenna to recieve TV. So if you have Cable or Satillite, you will not need a box at all.
8/12/2012 5:42:18 AM • Hitachi 51G500... • Answered on Aug 12, 2012
2answers
Hitachi 51g500 screen gone black
Yes worth repairing but not a crt problem. the crt's are powered by a high voltage transformer and sometimes it's caps that goes bad and in turn knocks out the crt's. but they are ok, it's in the high voltage line.
7/29/2012 7:14:34 PM • Hitachi 51G500... • Answered on Jul 29, 2012
3answers
51' projection tv(Hitachi 51G500A)
The Hitachi part number for the screen assembly for the 51G500a is KR02844. You can call a Hitachi parts distributor and see for yourself how much those things cost, but I warn you they are not cheap!
7/29/2012 7:11:37 PM • Hitachi 51G500... • Answered on Jul 29, 2012
51G500 51 in. Rear Projection HDTV-Ready Television went black white why?
It does not have a "color" tube, the model here appears to be a set with 3 picture tubes---do yourself a favor and unplug it and a box if used or a receiver if in the line--wait a bit and power back to see if the units connected will reboot.Also remember to check all the inputs to see if any have color: if using the cable wire direct to a set hook a DVD etc to one of the rear audio video inputs to see if same problem there.Let me know what you find--I answer about 400 questions here each week but try hard to help anyone who responds or needs more help.
5/24/2012 3:51:55 PM • Hitachi 51G500... • Answered on May 24, 2012
Has a black screen. The screen slowly went from dark to darker, then went to dark. I have a Hitachi CLU-572TSI projection tv
Not likely a do it yourself repair---loss of the filament voltage (6.3 volts) in the power supply of the set (some had issues where a resistor changes value).
5/6/2012 5:34:39 PM • Hitachi 51G500... • Answered on May 06, 2012
Red light on no picture or sound
kindly try to count the blinking led lights to diagnose the problem..after that go to this link www.fixya.com/users/bugoy31then choose any of my services offer..I will help you as much as possible..
2/4/2012 1:42:50 AM • Hitachi 51G500... • Answered on Feb 04, 2012
I have a hitachi 51g500a convergence problem i
you can and should use two of the same; the 150 and 110 are identical except the 150 is a higher current device.I usually replace both with the 150; be sure to remove all the old white heat sink compound and apply fresh as well as checking all the low value resistors around the two chips.Let me know if you need help or have questions.SD TECH
12/18/2011 5:14:29 PM • Hitachi 51G500... • Answered on Dec 18, 2011
0answers
The power is not coming on, and when it does it
Bypassing the V-Chip Lock
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip Lock menus. If you forget your passcode, you can view the locked TV without entering your passcode.This is done by pressing the number 9 and QV buttons on the TV remote control at the same time, when your passcode is requested.This process temporarily unlocks the TV. When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.Press HOME to exit the menu.
1/5/2011 9:50:42 PM • Hitachi 51G500... • Answered on Jan 05, 2011
3answers
Hitachi 51G500A Convergence Problem
Hi, 110`s & 150`s are both replaced by stk 392-120`s. which run waaay cooler because the 120``s are rated at 4 amps while the 110`s and 150`s are 3 amp devices , the real key is to make absolutely certain you are not buying generics (which are everywhere on the internet), there should
be NO black print on the back side and a 4 digit code (not 5) on the front, top right corner, the originals or OEM`s are never $8.99, usually run about $12-15 and are made by Sanyo but the word sanyo will NOT be on the IC`s , so go by the info above, be sure to check for burnt resistors next to the heatsinks as well, good luck, video-tek
1/2/2011 12:31:02 AM • Hitachi 51G500... • Answered on Jan 02, 2011
I have a Hitachi 51G500A
I hate to say it if you can fine one it would be from another scraped set it is a chore to do for a pro.
Recycle the set correctly.
SO sorry
10/3/2010 4:14:30 AM • Hitachi 51G500... • Answered on Oct 03, 2010
Where is the lamp located on my HITACHI 51G500A?
51G500a is a rear projection CRT type set----It has no Lamp--it uses three picture tubes.
What is the problem with the set? Verify model number posted here is or is not correct.
SD TECH
8/18/2010 6:46:00 PM • Hitachi 51G500... • Answered on Aug 18, 2010
Hitachi 51G500 51" Rear Projection HDTV-Ready Television Logo
60 questions posted
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
51g500 51 in rear projection hdtv ready
  • Televison & Video
