20 Most Recent Hitachi 57S700 57" Rear Projection HDTV Questions & Answers
first try going to the menu on the tv and adjusting the red blue and green tint....if not the u need to remove the front pannel and move the the the top left knob on the setting to lower the tint...
Hitachi 57S700... | Answered on Oct 04, 2015
Go to a channel that is in black and white and turn color all the way off.
Screen should be a black and white or gray color.
If green there is a fairly easy way to adjust--let me know what you find and I will tell you how to attempt the adjustments.
Hitachi 57S700... | Answered on Feb 19, 2012
You can get the manual on the link below. Just scrool down and type in the # code then click on download now.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good Luck
Hitachi 57S700... | Answered on Jan 01, 2011
This tv is under five years old?Yes,it is worth fixing.Over five,i would compare the prices for a new LCD tv and the quote priced from the Tv Tech.for the old tv.This tv have high voltage problems around the Deflection circuitries area.Could be any things burn in this area.The high pitched whine sound,i'm sure it is from the FBT-the high voltages flyback transformer,high voltages current have no where to go.Must hire a tv tech. to troubleshoots and replace parts on the Deflection circuitries area.Also the FBT could be dead too,because HV Current bounces back forth and have no where else to go.The prices to troubleshoot unknown problems is about $400 bucks and plus cost of replacement of parts.
Hitachi 57S700... | Answered on Dec 05, 2010
replace both of your STK ICs STK392-110s big black ICs
Hitachi 57S700... | Answered on Jan 08, 2010
You will probably find the captioning is turned on in the cable box and that's why you haven't been able to get rid of it through the TV. The box remote control should allow you to access the setup menu so you can turn off the captioning. Your cable company should be able to help you if it's not clear from the on-screen information.
Hitachi 57S700... | Answered on Apr 06, 2009
It sounds like the contacts on the on-off relay are stuck on. You can tap the top of the relay cover and that will shut it off (releasing the contacts) For a permanent fix, try taking the plastic cover off the relay and clean the contacts with a file (or just replace the relay)
Hitachi 57S700... | Answered on Sep 03, 2007
Without a remote control, you can't unlock it. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops; and by Online shopping.
Hitachi... | Answered on Feb 12, 2020
Soooo...execute it
Hitachi... | Answered on Jan 26, 2020
Simple answer to volume problem i have found there is a demo button on the tv which automatically turns everything down.
Hitachi... | Answered on Jan 24, 2020
Hitachi 57S700 57" Rear Projection HDTV Logo
17 questions posted
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
red screen
  • Televison & Video
