20 Most Recent
Apple Mac OS X 10.4 Questions & Answers
Mac Disk Utility Problem
1.Insert the Mac OS X Install CD or DVD.
2.Restart Mac, immediately after the bong, hold down the C key until the Apple logo appears.
3.When the Installer reaches the INTRODUCTION phase, click on Utilities at the top of the screen, and drop down to Disk Utility.
4.Click the First Aid tab.
5.Highlight the boot hard drive volume or partition.
6.Click Repair Disk.
7.Repeat steps 5 and 6 until the scan comes up all clean and good (and run it one more time).
8.Quit Disk Utility and the OS Installer and reboot.
9.Firewire Target Disk Mode is another option we should know about.
Cheers.
While logging on to ireps
THIS IS BECAUSE CERTIFICATE IS NOT INSTALLED PROPERLY. U NEED TO IMPORT UR CERTIFICATE ON BROWER AS WELL IN TOKEN AND REGISTER IT ON IRPES WEBSITE IF THERE IS ANY CHANGE IN CERTIFICATE
Why video quality in mac is not good it seems
Try going to your System Preferences which is in your Utilities folder located in your applications folder.
In system preferences, click on the button called "Displays"... from there, adjust your brightness (turn it up).
Also, if video quality is bad in Quicktime - open quicktime and go to Window tab located at the top right near the help tab. Then click on Show AV Controls. You can adjust brightness from there.
Also, within the Displays button, try calibrating your monitor by following the simple instructions.
Hi, I have just bought a logitec lan-w300n/u2 for
You can call at Apple Customer Support Number 1800-204-4427, they have a team of experts that can help you to resolve that issue over the phone in a minute.
So be don't Hesitate to call Toll-Free +1-800-204-4427
Sound Problem with MAC OS X 10.4.11
This sounds obvious, but the system volume could be down. Go to the System Preferences, and select "Sound". Make sure the output voumne is turned up, and the mute is not on.
If that doesn't work you could try "zapping the pram".
- Shut down the computer.
- Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
- Turn on the computer.
- Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
- Hold the keys down until the computer restarts and you hear the startup sound again. Continue this until you hear the startup sound four times.
- Release the keys.
Hp officejet 725 compatible with Apple OSX?
If you simply go to hp.com and look up the Officejet 725, and then look for Drivers, you'll see that they only have Windows and Linux drivers.
Therefore, unlikely that you will have support for OS X on it - other than maybe printing...
CD/DVD drive will not accept any disk I try to put in it.
Do you have any small children in your house?
Seriously, I have 6 children. One (or two) of them put a quarter and two flat washers in my slot load CD drive. Took me over an hour to take it apart to fish them out.
I've also had a friend whose young children managed to get 2 cds into the slot load at the same time.
So, my primary suspect is a foreign object has gotten into the drive. I've never had a CD/DVD drive fail on an iMac other than that.
However, if it is a foreign object, you will need to take it in for repair, most likely. It is difficult to see in there. and even more difficult to grab the object.
I suppose that the cable could have become disconnected. I really doubt that the drive was a lemon, seeing that it worked for a year.
Imac cd drive will not accept disc
try external drive. Go to ifixit.com for instructions on how to replace imac optical drive. You can buy replacement drive off ebay cheaper than ifixit prices for parts.
How i can solve problem with error code ADM:0161
HI,
This message may be one of the messages generated when you perform a Scan and Repair operation. SUPERVISOR cannot update data in the specified table due to a corrupted repository.
website at the time login then there may be following reasons for this error:
- You have not installed your Digital Signature Certificate in your browser.
- You have not installed the appropriate driver for your token or installed driver corrupted.
- System/Browser not able to read the Digital Signature Certificate from your token device.
- Your Operating System should be updated as given below.
Thanks,
Apple Support
Hello...
Anong ibig mong sabihin gusto mo bang installan ng Windows ung Mac computer mo? So far bro hindi pwedieng gawin yan dahil walang drivers. pero kung ang gusto mo is mag windows sa loob ng Mac pwede since program lang un. pero kung Windows ang main OS walang drivers na available kaya hindi pwede.
Delete bookmarks
Assuming you are using Safari, go to the "Bookmarks" menu and select the "Edit Bookmarks" option. Here you will be able to select multiple bookmarks and delete them.
Other browsers work is a similar fashion.
Mac pro administrator password forgot
If you cannot get the CD, you can create a bootable USB disk as a startup disk. If you then go into Disk Utility you will be able to reset the admin password.
Disadvantages of Mac OS
Advantages of MAC OS:Resistance to viruses - good for risky computer venturesWorks very well with certain graphic applications in a MAC computer.Disadvantages:Very Limited software for platformExpensive because there is no competition from other manufacturersLimited adoption by computing public
