20 Most Recent
Hitachi 61SWX10B 61" Rear Projection Television Questions & Answers
Hitachi 61SWX10B- no sound & static
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
Convergence problem
If
you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over
2350 posts now. All are related to
electronic equipment repair help. If
you check the site in Timeslide option, which can be selected from the dropdown
list at the top left side of the display window, it will make search easy. Details about convergence adjustments have been described with illustrations.
I have an older model
TURN IT OFF AND DO NOT TRY TO USE---if a thin line left to right in middle of screen it is vertical problem---the set should shut down but even seconds count here--this can burn a mark on all three picture tubes instantly and it is permanent.
Problem if small line left to right in vertical circuit.
Let me know what you know and I will try to help--I know these sets very well.
SD TECH
What was the retail price
Try to Google the model number, about the only way I can think of to find this information. It was at least 2,000 at one point.
I have arear projection Hitachi
Very common problems for DLP tvs,will get worst as times go by.Tv probally have a problems known as a convergence problems,it is dead.Tv have colors lines R,G,B unlevel on the pictures?Crooked pictures have mis colors alignments?Yes.There is no way manually to do an adjustment to fixed for this.Try push the tv remote button that said Magic Focus button.If the tv have data processing never completely done and have a error message and stop.Ur tv 100% have a dead tv convergence board,the tv convergence board must have it parts to be replaced like 2 STK convergence ICS and some or all of it resistors too.Than tv will be able to run the tv remote Magic Focus again to have a 100% data processing with no error message,tv to fixed this problems.The shop will cost u like $300-350 for parts and labors.
MY COLORS ARE OUTTER PLACE
You will need to replace Both of the Convergence ICs ,Located on the left hand side board in back of TV. They are Big Black ICs and will have the part Number on them STK392-110 use the 120s.
Mats has ICs ,but tell them you want the convergence Kit for your Model it will have ICs and Resistors that come with it. ,You will also need to check Low Ohm resistors in the same circuit.
Mats Electronics 1-800-628-1118
PS. What ever you do (DO NOT) Clear the DC Ram if you do, it Takes over 6 hrs to realine convergence.
I have a hitachi 62in.
There is most likely an issue with the Surround PWB since you have the DP17 chassis. I would check the following items on the surround board. I have seen them all several times with the DP17
IT02 Shorted, pins 92 and 93 caused by Solder splash. IT02 Is also known to fail. Also pins 42, 43, & 44 have been known to have cracked solder
IT05 pins 20 & 21 shorted also Seems to have been caused by too much solder.
IS13, pins 1 & 2 shorted ( too much solder
Also check for cracked circuit trace patterns under IT05If you need further assistance let me know.
I push magic focus and
You need to get into your menu and find where you can reinstall factory settings, or default settings. Also you can try the realignment......
Picture is unstable (jittery) colors (especially
Ur tv have a problems known as a convergence problems it dead.Tv have colors lines like R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Tv have a dead convergence board,board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the convergence board to solved the tv picture convergence problems.The shop,will coat u like $300-350 for parts and labors.
