20 Most Recent Hitachi 42EDT41 42 in. HD-Ready Plasma Television Questions & Answers
LCDs are worth it to have as to a Plasma set as plasma tvs do need time to warm up LCD and LED tvs dont have that warm up time to wait for things to smooth out however if you wish to have the tv serviced it is fully up to the owner of that TV now mind you there is also OLED tvs out there in the market as well and with the cost of LCD tvs going down to about 500 bucks you might be more interested in that but thats my IMO on buying a TV set
Hitachi 42EDT41... | Answered on Mar 02, 2017
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Hitachi 42EDT41... | Answered on Jul 28, 2014
Is the t.v new or its been some years that you bought it?Have you checked the DC voltages leaving the power supply? If not, let's try that now.
Put your red lead on each pin leaving the power supply one at a time, with your black lead on any exposed chassis metal for ground. Stick that red lead down into the connector so the lead makes contact with the pin.
Be sure the TV is turned on.
It can be a fault in the screen if it is under warranty i suggest you contact the shop or supplier.
Best regards,
Daniel
Hitachi 42EDT41... | Answered on May 10, 2014
Check and replace the main power regulator board [SMPS board] as card basis. Contact any service technician.
Gopakumar Gopalan Google
Hitachi 42EDT41... | Answered on Feb 24, 2014
Mine has the buzzing. I even created this current one out of 2 damaged ones, the original internals did it as do the internals I took out the "new" one I got (it had a smashed screen). I noticed it stops completely when muted, but not when the volume is on 0. It also gets louder when the contrast is higher (just flick between the preset PICTURE MODE's). I think it's something to do with the internal speaker cables perhaps running too close to the display circuit or whatever (Im not sure what causes it, its normally electrical interferance being picked up by an unshielded cable). I'll no doubt get hacked off and reopen it soon to look about. I'll post back when I do, may be a few months though!
Hitachi 42EDT41... | Answered on Oct 02, 2013
Check whether the AC is present to TV. Try it by an other AC outlet. If it has been working fine, there should be no problem at all.
Hitachi 42EDT41... | Answered on Sep 13, 2013
Please read all the info before you start and if you have any question please feel free to message me at pleasefixitdave@yahoo.com or just give me a call @ Cell # 1-503-432-9904 Ask for Dave! What you'll need to do is remove the stand and the back cover. Once you have both the back cover and stand off you'll need to put the stand back on the TV so that you will be able to set the TV up right! Then you will need to locate the Y sustain board. The Y sustain board is the board that is to the left side of the TV if you are looking at the TV from the back side. The Y sustain will have a large heat sink on it 3 1/4 inch's wide and 6 inch's long. There is a small heat sink 3/4's of an inch wide and 3 1/2 inch's long just above the large heat sink. A little to the right of the larger heat sink. The little heat sink also has two large capacitors just to the left of it. Once you have located the small heat sink you will want to look just to the right of it and you'll see two Blue with Yellow centers adjusters.b5e4dcb.jpg You do not want to touch any of the adjusters other then the two that has the location #'s VR1 & VR2 next to them. Please make sure you have located the right adjusters by making sure that the location # next to them is VR1 & VR2. Start with adjuster VR1. Before you make any ajustments take a felt tip pen and make a stright thin line over the top of the Blue with yellow center adjusters. This will help you put the adjuster back in to the factory setting position if you need to start over and it will also give you an ideal as to how much you have adjusted the adjuster. At this point you should have the TV with the back cover off and the TV in the up right position with the stand on the TV. Now you will need to find a friend to watch the screen while you make the adjustment to Location # VR1 & VR2. plug in the TV and turn it on. The TV should be cold, another words if you have had the TV on at all let the TV cool down for about an hour or so before you do the adjustment. Start the adjustment by turning VR1 counter clock wise slowly untill the specs on you screen go way. If the specs on you screen get worse then put the adjuster back in the factory set position and turn the adjuster VR1 clock wise until the specs go away or lessen. In some cases you will not be able to get ride of all the specs but you will be able to lessen the amount of Green or Red specs on the screen. If adjusting VR1 dose not completely clear all the Red or Green pixels from your screen make the same adjustments to VR2! WARNING: Plasma televisions use high voltages to display images on the screen. Be sure to unplug your unit, and then press the power button on the front panel to discharge the capacitors in the unit before beginning to open up the case. Always observe the necessary precautions when working around electrical equipment and never touch anything with your bare hands that may be carrying a stray voltage. By following these instructions you agree to assume all risks involved with the repair of your unit, and agree to hold me harmless of any damages that may result to either you or your television from the following of the instructions on this page. Please feel to message me or give me a call if you have any question regarding the repair of your TV! Thank you! 03.gif Dave All TV Repair Cell # 1-503-432-9904 pleasefixitdave@yahoo.com
Hitachi 42EDT41... | Answered on Aug 29, 2013
Hi
This is not really a very simple fix but it can be done if you are ok with stripping down your tv, Please see the following video.
Hope this helps
Hitachi 42EDT41... | Answered on Aug 27, 2013
i have a stand for that tv and live near nashville. still need 1 ?
Hitachi 42EDT41... | Answered on Feb 19, 2013
You can get info at ctechnicians.com
Hitachi 42EDT41... | Answered on Feb 08, 2013
It's either x-main or logic board... Take it to a qualified shop and I think you'll be impressed... Most of these are repaired at module level now and it makes the repair relatively inexpensive.
Bill
Hitachi 42EDT41... | Answered on Jan 31, 2013
Check its backlight inverter board. Visit the site named 'Electro-help' for more details. Click this link. View it in Timeslide or Flipcard option, which can be selected from the drop down box menu by the Sidebar tag, at the top left corner of the display window. You can also click the Home tab to see the latest updates. It will make search easier. There are more than 1400 posts to different brand TVs till now. Setup proceedings and code list to different brand remote controls also included. Pull up older posts or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
Hitachi 42EDT41... | Answered on Dec 14, 2012
Sustain drivers can make this kind of fault. Panel too tshould suspected. Check the site linked below and see the illustraations there. There are illustrations of faulty plasma display panels, which can't be included by this window. Check it and see which type of fault to your TV resemble with. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Hitachi 42EDT41... | Answered on Nov 28, 2012
l would suggest a call to Hitachi customer service if Hitachi or to the maker if not.
Hitachi 42EDT41... | Answered on Nov 08, 2012
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
Popular Tags
206 questions posted
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
need tv stand hitachi 42edt41a
  • Televison & Video
