20 Most Recent
Guess G13552L Womens Swarovski Crystals White Mother of Pearl Chill Watch NEW - White - Metal - 9.5 Questions & Answers
How to set date
just push the screw out. and move it clock wise ... if time is set then try to push it a second jerk then try to set time..... best of luck with try,
P.S nice watch :)
Hello, I got a pair of Guess sunglasses, GMIP68,
You would have to check with their customer care I believe. If you share yoour details and depending on how long ago you purchased it, they might be able to help you with options. And if not, then you can always get it fixed from a local shop.
How to put a frame in my picture
Hi looking at your problem it doesn't seem to pertain to sunglasses, putting this into a more appropriate category then you have a better chance of actual getting this question answered. Hopefully I was helpful.Have a nice day.
530 Access denied -ERR [AUTH] invalid
hi
The question you have asked is not clear and specific . i am really sorry i cant help with this question please be more specific so i can help you out
thanks
Left side broke
hi
The question you have asked is not clear and specific, but let me try to help you. The left side of your sunglasses is broken it may be your lens or frame,
The solution is if your sun glasses have warranty or guarantee please approach the showroom where you brought shades or you can approach some other dealer showroom they may not have your brand but they will repair it for a charge.
If you are satisfied with my answer please vote three thumbs up ..Thank you
How i know if someboby has erased me from yahoo
if some one has reased you from yahoo try sending request again ,if they are still in your friends list or they still they have you on your list yahoo inform you telling wether you are there in that list or not
Oakley screw fell out
1. PLACE THE FRAME ON A FLAT SURFACE WITH THE SCREW HOLE FACING UP.
2. TAKE THE SMALL SCREWDRIVER AND INSERT THE REPLACEMENT SCREW INTO THE HOLE.
3. TURN THE SCREWDRIVER CLOCKWISE TO TIGHTEN THE SCREW UNTIL IT IS SECURE.
4. ONCE THE SCREW IS IN PLACE, MAKE SURE IT IS TIGHT ENOUGH TO HOLD THE FRAME TOGETHER.
3/28/2024 10:20:58 AM •
Clothing...
Answered
4 hours ago
How much would getting a wedding dress made cost?
The cost of getting a wedding dress made can vary greatly depending on factors like the design complexity, quality of materials, and the expertise of the designer. On average, it can range from a few hundred to several thousand dollars. It's important to consider your budget and discuss pricing with the designer to find the best option for you. For best designer lehengas, saree and ethnic wear you can check Mirraw Luxe online. Visit now: https://www.mirrawluxe.com/trends/wedding
3/8/2024 1:22:32 PM •
Clothing...
Answered
on Mar 08, 2024
How to clean white shoes properly?
Cleaning white shoes can help maintain their appearance and keep them looking fresh. Here's a step-by-step guide on how to clean white shoes properly:Materials you'll need:1. Mild soap or detergent2. Soft brush or toothbrush3. White vinegar or baking soda (optional)4. Water5. Clean cloth or sponge6. Old newspapers or paper towels Steps:1. Remove Loose Dirt: Knock your shoes together or use a brush to remove loose dirt and debris. You can also use a soft cloth to wipe away any surface dirt.2. Remove Laces: Take off the shoelaces. You can either clean them separately or replace them if they are too dirty or worn.3. Pre-treat Stains:If there are stubborn stains, pre-treat them with a mixture of water and a small amount of mild soap or detergent. You can also use a paste made from baking soda and water for tougher stains.4. Soak Laces:If you removed the laces, soak them in a mixture of warm water and mild soap. You can also add a bit of baking soda or white vinegar to help with stains. After soaking, scrub them with a brush or toothbrush, rinse, and let them air dry.5. Wash Shoes: Mix warm water with a small amount of mild soap or detergent. Use a soft brush or toothbrush to scrub the shoes gently. Pay extra attention to stained or dirty areas. Be careful not to use a brush with stiff bristles, as it may damage the shoe material.6. Rinse Thoroughly:Wipe off any soap or detergent with a clean, damp cloth or sponge. Make sure to remove all residue.7. Dry Properly:Stuff your shoes with crumpled newspaper or paper towels to help them retain their shape and absorb moisture. Let them air dry in a well-ventilated area. Avoid direct heat sources like radiators or sunlight, as this can cause the shoes to yellow.8. Clean Soles:Clean the soles of your shoes separately. You can use an old toothbrush or a small brush to scrub away dirt and grime. A mixture of water and mild soap or a specialized sole cleaner can be effective.9. Protect and Maintain: Consider applying a stain and water repellent spray to protect your white shoes from future stains. Regularly clean your shoes to prevent dirt buildup.10. Polish (for Leather Shoes):If your white shoes are made of leather, you can use a white shoe polish to restore their shine. Make sure to follow the instructions on the polish container.Remember, prevention is key. Try to avoid wearing your white shoes in muddy or extremely dirty conditions, and clean them regularly to keep them looking their best.
12/28/2023 4:24:01 PM •
Clothing...
Answered
on Dec 28, 2023
