20 Most Recent Hitachi 42PMA400 42 in. Plasma Television Questions & Answers
When switching on my plasma 42pma400a ,the screen lights up for a second and then screen goes off(completely off mode) ,then led goes on orange from green.The real problem is that i dont know where is
Unfortunately it could be any of several boards, plasma sets are harder to repair because they have a lot more boards than a LED or LCD TV, its probability not worth repairing.
11/14/2017 2:40:50 PM • Hitachi 42PMA400... • Answered on Nov 14, 2017
0answers
Hitachi 42 PMA400e Plasma Tv.
Just get a headphone jack that does not shut off the speakers and have your dad plug his headphones into that.
3/22/2017 1:47:15 AM • Hitachi 42PMA400... • Answered on Mar 22, 2017
Display error no audio also
The problem may be your cable box. If your box is a Motorola , swap it with another possibly from another room in your house. I have run numerous service calls in Dallas / Ft. Worth area only to find the cable box by {MOTOROLA} WAS DEFECTIVE.. Your cable company should also exchange it for free. If the tv does turn out to be the problem, suspect the 24v or 12v from power supply to be low. Probable cause defective capacitors or regulator ic's, or associated zener diodes or open resistors. GOOD LUCK AND LET ME KNOW HOW IT TURNS [email protected]
3/17/2014 5:25:39 AM • Hitachi 42PMA400... • Answered on Mar 17, 2014
7 year old plasma screen 42PMA400A picture
You need to replace your horitzontal buffer boards...they are located on the right side of your tv and there will be two of these. They buffer the signal and cause a problem just like yours.
Best of luck!! thank you!
6/14/2011 1:16:14 PM • Hitachi 42PMA400... • Answered on Jun 14, 2011
I have an Hitachi 42
I also have this television, and it baffled me too. Apparently the 42PMA400E isn't so much a television, it's more of just a "display unit". It hasn't got any built-in channels (can't even connect an aerial into it) and hasn't got any speakers either. To use as a television, you need to connect a reciever (I use a DVD player, as I only use it for the Xbox) to it to display the video, and get some surround sound speakers to connect to the DVD player.
3/21/2011 12:21:37 PM • Hitachi 42PMA400... • Answered on Mar 21, 2011
Intermittent noise coming from back of screen
No,fan in Plama tvs,fan only in DLP tvs.One of the power transformer in the power supply board is not give out the right high voltages.
3/19/2011 1:39:42 PM • Hitachi 42PMA400... • Answered on Mar 19, 2011
Same problem as mark_free256 posted
There are two things that can cause this, a buffer board and the plasma panel itself, the bad news is that there is no way to determine what one is causing it without putting the buffer board in the set. If the buffer board fixes the problem then case closed, if it does not fix the problem then the plasma panel itself is bad and the tv will be non repairable because the part will cost over $1300! Yes that is not a typo it is really over $1300.
Now if you have a professional install this for you, you can expect a bill of around $200-$400. Now that repairman is taking a risk because there is no way to know if it is going to fix it because the manufacture made no way to troubleshoot it, therefore he might pass the risk off to you and say something like:
If you want the board replaced and it fixes it then it is going to be $200-$400 (whatever he charges) BUT if I put the board in there and it does not fix then problem then there will be a $150 fee for trying, this is to cover my time and the expense of sending the part back and the restocking fees I will incur.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
1/15/2011 1:51:19 AM • Hitachi 42PMA400... • Answered on Jan 15, 2011
We have a Hitachi 42PMA300A
Hi, when I open it got the sound but no picture?
1/2/2011 8:46:04 AM • Hitachi 42PMA400... • Answered on Jan 02, 2011
0answers
Excessive fan noise. can it
Excessive fan noise means that either the fan bearing is defective, or that dusti inside fan is making noise.
The best thing to do is replacing the fan. In some case hoovering the fan may fix the problem. Hoovering may damage electronic parts and should be done from distance using a low power hoover.
That is one of the reasons why replacing the fan is a better choice.
The fan is held by four screws, and it is not much different by a computer fan. As a disclaimer I must remind that this is a plasma TV, and that is should be repaired only by an authorized Hitachi tecnician.
Here the spare part for this model.
There may be one or two fans (there are variations of same model). There is a fan in the H1 panel, that is usually making the noise. Details and disassembly explained in service manual.
I uploaded service manual here:Click here to start download..
If the link does not work, start from HITACHI 42PMA400E PLASMA TV SM.PDF.zip
10/18/2010 10:24:40 AM • Hitachi 42PMA400... • Answered on Oct 18, 2010
Colour changes to yellow frequently
Ur backlight video board is dying,must replaced.
11/22/2009 7:07:01 AM • Hitachi 42PMA400... • Answered on Nov 22, 2009
Hitachi tv shuts off . When I turn on the TV iMessage says please wait then turns off two seconds later.
That sounds like it is not booting properly. I would check for correct power supply opperation and if not that, look for a software reloading procedure in the user instruction manual.
2/11/2024 9:04:18 AM • Hitachi... • Answered on Feb 11, 2024
HI MY NAME IS MAZEN FAHMY I haVE DIODE T3D 36 THIS ZENER & DIODE 2 AND THIS IS IN DATA SHOW HITACHI CP-X3030WN FIX POWER.
https://www.google.com/search?q=DIODE+T3D+36 https://www.google.com/search?q=HITACHI+CP-X3030WN
Original Projector Ballast Main Power Supply For Hitachi ...
AliExpress https://www.aliexpress.com > item Original Projector Ballast Main Power Supply For Hitachi CP-X3030WN. 1/1. 1. US $52.62. Price shown before tax. Free shipping?Free returns. Original Projector ... US$52.62
Projector Power supply For CP-X2530WN CP-X3030WN ...
AliExpress https://m.aliexpress.com > item Projector Lamp Ballast And Power Supply For Hitachi CP-X2530WN. US $80. Projector Lamp Ballast And Power Supply For Hitachi CP-X2530WN. EUC 215g N/T05 ... US$50.00
CP-X2530WN/CP-X3030WN CP-WX3030WN
Projector Central https://www.projectorcentral.com > pdf > projecto... power supply make the projector turn on. Setting up. ?This product is also designed for IT power systems with a phase-to- phase voltage of 220 to 240 V ... 118 pages ....
12/5/2023 2:26:21 AM • Hitachi... • Answered on Dec 05, 2023
Change input on Hitachi LCD TV model LE65K6R9 without remote?
I'd unplug/disconnect the Roku and after 30 seconds try the control button on the back. If you can change the input do so, then plug the Roku back in. Until you use the input button on the back to change input to Roku, you should be able to use the other buttons on the back to control the TV. If this does not work, unplug both the TV and the Roku. Wait maybe a minute, then plug the TV back in and follow the above instructions. Here are other alternatives: Using physical buttons: You can find the physical buttons on the left or right back side of the Hitachi TV. Using these keys, you can change the input, adjust the volume, or turn on Hitachi TV without a remote. Press the Input button located at the back or side of the Hitachi TV. The list of connected sources will appear on the TV screen12. Using external devices: Connect a wireless keyboard or mouse to your Hitachi TV and change the input1. Buy a universal remote: You can buy a universal remote to control your Hitachi TV and change the source.
10/13/2023 9:21:56 PM • Hitachi... • Answered on Oct 13, 2023
How to remove small popup bottom left of Hitachi smart tv screen.
A little popup that appears in the lower left corner of your Hitachi smart TV screen may be related to one of the TV's settings or capabilities. You can attempt the following actions to get rid of it: 1.Investigate notifications: Smart TVs occasionally show notifications for different events or upgrades. If there are any notifications, look for them and then clear them by following the on-screen directions. 2.Applications and Inputs: Make sure all programmes and inputs are closed. The popup may occasionally be connected to an input source or app, which can be closed to get rid of it. 3.On-Screen Display (OSD) Off: There might be an OSD option in the settings menu on Hitachi TVs. Try disabling OSD or changing its settings to see if it gets rid of the popup. Verify any software/firmware updates: 4.Make that the most recent firmware or software upgrades are installed on your TV. Pop-up windows may appear as a result of faults in outdated software. Look for a software update option in the TV's settings menu. 5.Firmware Reset: You can conduct a factory reset on your TV if the problem persists after you've tried various troubleshooting measures. The default values for all settings will be restored as a result. Make cautious to back up any crucial data before doing a factory reset because doing so will also remove any customised settings and data. 6.Message Hitachi Support here: If none of the aforementioned fixes the problem, it's a good idea to get in touch with Hitachi customer service or refer to the TV's user manual for detailed instructions on how to get rid of the popup. Regarding External Devices: 7.The popup may be related to any external devices you have connected to your TV, like a cable box or game console. Make sure that these gadgets are operating properly and that the settings have been changed as necessary. Keep in mind that depending on the type and software version of your Hitachi smart TV, the precise processes and options may change. For instructions unique to your TV model, consult the user manual, or go to the Hitachi website for further help options.
9/30/2023 6:30:41 PM • Hitachi... • Answered on Sep 30, 2023
Hitachi LE42S704 none of the HDMI ports work, need to update (i think)
Are you getting the various HDMI inputs on the screen but it acts like nothing is connected? We have repaired hundreds of TV's with no HDMI signal over the years and have never had an update correct this issue. There is an IC close to the HDMI input jacks (U501) that decodes the data, that's always been the defective part. You can order the part and change it but you will need advanced soldering skills and the equipment to do it, I'd recommend replacing the main board if you can find one.
5/23/2023 4:18:27 AM • Hitachi... • Answered on May 23, 2023
Hitachi 42PMA400 42 in. Plasma Television Logo
20 questions posted
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
hitachi 42
  • Televison & Video
