20 Most Recent
D-Link (R) DIR632 WirelessN 8Port Router Questions & Answers
Dir-632 slow throughput on wired lan
Try a factory reset. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
I am trying to use a d-link dir 632 but i dont have the setup disk
Hi Welcome to FixYa. I can definitely help with your issue. 1. Go to the product page for your router
here: 2. You will see a picture of your router and links to Overview, Works with and Support Resources to the right of the picture. Click on "Support Resources." Then choose your Country-if it is not listed, click on More Countries and select yours from the list.3. Then click on "Additional Downloads" link. You will see Applications that you can download. Scroll down until you find the application "QRS" Utility (Quick Router Setup Utility) 5.04 8/02/2010. 4. Download and save to your desktop. Then click on program to open it. Follow the instructions to setup your router. You can also download a Quick Install Guide and a Product Manual from the Support Resources page that you went to in Step 3.Let me know if this solution helped resolve your issue or if you still need my assistance. .Send me a comment and I'll be glad to help. Thanks for using FixYa!
Laptop won't connect to router
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link's configurationURL..http://192.168.0.1The default login = adminThe default PW = blank (just press Enter)You can now change the default adminpassword.You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
I've been trying to play
Check out page 39 of the user manual or click here
http://www.manualowl.com/m/D-Link/DIR-632/Manual/156044?page=39
Different games have different settings so I'm not 100% which configuration you will need.
Also, if you navigate to the
configuration setup by opening a web browser and entering the IP address of the router (ie:192.168.0.1).
Click on.Setup.and then click.Wireless.Settings on the left side. 2. 3. 4. 5. 6. 7. Next to Security Mode, select WPA-Enterprise.
Next to WPA Mode, select Auto, WPA2.Only, or.WPA.Only. Use ... Key Update Interval, enter the amount of time before the group key used for broadcast and multicast data is changed (3600 is default).
Next to Authentication Timeout, enter the amount of time before a client is required to re-authenticate (60 minutes is default).
Hope this helps :D
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
I have a D-link DP-300U device that I can not access
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
How to change password D-Link router DIR-655
the manual is free , at dlink dot com
you push the reset button for long time per manual 15sec (iirc)
the release it and now all defaults are set.
per the manual, google dir-655 manual.
easy as pie if you just read the manual.
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
D-link Router Tech Support Phone Number 1^877SCAMMER 69}}.support
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
