Do you have a a pair of shoes that you bought not too long ago and the sole is coming apart? If you rather not risk buying another pair of the same shoes only to have them come apart, then this is the article for you.
Difficulty: Easy Instructions Things You'll Need:
1.
Get a tube of super glue--any brand name should do. Just the regular type should do, no need for any extra strength formulas or special types. Make sure the tube has been properly opened at this time--the seal on the tube has had a hole punched in it, in other words.
2.
Get the shoe(s) that need its/their sole(s) fixed. Where the sole is coming apart on the shoe, squirt in a good amount of super glue, but not too much that it will gush out. (If it does, try to wipe off the excess).
3.
Hold the sole and shoe together for the recommended drying time or until they seal. Try not to get any glue on your fingers at this time, as it can stick flesh to other objects.
4. The sole should be fixed at this time. Sometimes it has to be done over if the drying time hasn't been followed or the glue might have some problem with it. Repeat this procedure for other shoes to be fixed
A fascinator is a a headpiece that is a modern alternative to a hat. It's usually worn as a large, feathery decoration that is attached to a hairband or clip.
1 questions posted
1 Questions
1 Questions
