20 Most Recent
Belkin Surf N300 Wireless N Router Questions & Answers
My belkin has to be restarted each time using wireless
When the "wireless adapter" was installed in your laptop, a
so-called wireless manager similar with the wireless zero configuration
of winxp was installed as well.And the news is,
everytime you boot up your system, it will automatically enable the
wireless manager that was installed with the adapter. That's why you
have to go to services.msc all the time so that you can use the wireless
zero configuration.you need to troubleshoot the adapter ..and restart your pc..**If you need any kind of technical assistance you can contact
support cell at here
Is there a fix to wii error code 50300 ?
The Wii console's internet connection settings are not correct. This could include your network name (SSID), WEP or WPA keys, or any manual settings you may have entered.
It's possible something has changed since you last connected online with your Wii console. Try setting up a new connection file, using your router's settings.
While "Search for an Access Point" is the easiest and recommended connection type, your network may require you to use the "Manual Setup" option.
If the problem persists, try our general troubleshooting for tips.
If you are still getting this error code, please call 1-800-255-3700 for further assistance.
For more help visit
cbrtechsolutions
What is the security key of router n300
read this
http://www.belkin.com/networking/manual/MAN_F7D6301_v1_8820-00697_Surf_N300_N_Router.pdf
LOST ROUTER LOGIN PASSWORD
If you have forgotten your personal router login password there is no way to recover it. You will have to reset the router. This means all the settings on the router will be reset to factory defaults. It also means that all your connected devices will need to be connected again with the new security information (WEP, WAP, etc,) . You will need the default admin login name and the default admin password. This can be found in the user guide that came with the router. This can usually be found online at the router manufacturers site.
There is usually a button or a switch hidden in a pinhole opening on the back of the router. Pressing and holding the switch for 10 seconds or so will cause the reset and usually the LEDs will flash and blink for several seconds as the router firmware resets and clears out the old information.
If you are trying to get into someone else's router illegally there is no way to find out their login password.
For future reference, write the password down, or a hint at what the password is, on a piece of tape and secure it on the bottom of the router. I use my cell phone memo function to store all my passwords.
I am trying to get wif on my samsung galaxy it tells me get guest password can you help
You would need to refer to your Belkin's instruction manual for how to set up WiFi on it. The password for any WiFi hot spot is unique to that hot spot so there is no general 'guest' password per se - it depends on how you setup the WiFi router.
WiFi routers also have a web-based interface where you can open a browser from a connected PC and manage the device. Again, the device's instruction manual will tell you how to do this.
If the router was supplied by your internet service provider you should be able to call them for help.
