20 Most Recent Jbl Eon 515 Eon515 15 Powered Portable Speaker PA Dj Questions & Answers
Eon 515xt - the 3 volume buttons move in and out about 1cm..is this normal or has something come loose inside?
Sounds about right to me. I have 2 eon G-15s. If you don't hear any cracking sounds you should be ok. I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
2/20/2018 12:13:20 PM • Jbl Eon 515... • Answered on Feb 20, 2018
JBL EON 515 XT - fades out on it's own, then comes back on...
Sounds like bad power supply capacitors
2/25/2015 9:18:23 AM • Jbl Eon 515... • Answered on Feb 25, 2015
Jb leon515 one speaker cutting out after about 1 hour
It's probably a thermal problem with a component. You should take it into a repair shop as it is not user serviceable.
10/11/2014 3:57:02 PM • Jbl Eon 515... • Answered on Oct 11, 2014
Loud buzz/hum started on jbl eon 1500 powered speaker one side only after power cut off and sudden power back on makes same noise on it`s own as well as with mixer etc could this be a transform
For some reason the soft on protection circuit has failed. it is not a simple fix and would require the amplifier module to be removed from the speaker to assess the damage.
3/11/2012 12:36:32 PM • Jbl Eon 515... • Answered on Mar 11, 2012
I have a pair of
Make sure you are driving this with a balanced input XLR or TRS type cable. The driving device should have the SAME type output...
7/31/2011 10:41:37 PM • Jbl Eon 515... • Answered on Jul 31, 2011
I have a pair of JBL pro G730 & Crown XLS 602 amplifier. Can someone guide me how to connect these and the position of the switches as there are no labels on them. Thanks .
In the USA, JBL G730 cabinets come with 1/4" connectors instead of Speakons normally. Either way, the switch on the rear of the cabinet on the crossover is a pad for the horn which lowers it's output. Normal is the middle position, upper the horn is louder, lower the horn is softer
10/30/2018 3:48:59 PM • JBL Music • Answered on Oct 30, 2018
My JBL EON 515 lost
The corrosion is probably due to humidity. The other issuses will requier it goes to the nearest JBL service center Customer Service
9/2/2017 6:25:33 PM • JBL Music • Answered on Sep 02, 2017
How do I connect a 8channel mixer to a Kustom PA PA112S Powered Sub and 2 JBL EON615
I'd have to know the make and model mixer to properly advise you. In general, if I were you, I'd come out of the L/R mixer outs to the JBLs and run the sub from an aux send set to post faders. However, I would suggest getting a different sub. That one will not keep up with the eon's. You would probably need 4 of them to get close to matching.
7/13/2016 1:53:11 AM • JBL Music • Answered on Jul 13, 2016
How to play my acoustic guitar on my my jbl avr134 home sound system it does have a amplifier I want the steps for it plzz
An acoustic guitar, unless it is an electric type, will need to be played near a microphone in order to provide a signal for the sound system and the microphone or the guitar will have to be connected to a compatible amplifier input. Impedance matching is not so important unless high quality is required but matching the sensitivity or gain of the input to the output of the source is important for optimum performance. A moving coil microphone has an output of just a few millivolts and a crystal microphone can produce an output of around one volt.
8/10/2015 3:41:12 AM • JBL Music • Answered on Aug 10, 2015
How do i link 2x tr125 jbl speakers to 2 mr922 jbl speakers
The connections are pretty straight forward, but it will depend on what amplifier you're driving them with. Normally, I'd connect the two TR to one side of a stereo PA amp and the two MR to the other side. All four cabinets are rated at 8 ohms, so running tow parallel per side would give you a 4 ohm load on each channel which would be a common load for most stereo PA amps. However all this would depend on your gear and what you need to accomplish. If what your question really meant is how do you connect all 4 to one channel, you can't as in most cases the total impedance would be too low and you'll fry your amp. If you can be more specific about your system we could be more helpful.
3/18/2015 12:08:23 AM • JBL Music • Answered on Mar 18, 2015
Horn wiring diagram
Yellow is positive, yellow/black is negative.
12/14/2014 5:31:04 PM • JBL Music • Answered on Dec 14, 2014
0answers
I Bought the Denon Mc2000 Dj Controller, The Place
you are getting reverse polarity, meaning the speakers on one is the opposite as the other, black>red red>black, thus only getting vocals or music. If you need further help, I’m available over the phone at https://www.6ya.com/expert/ernie_b93ee48ba0eab50b
11/22/2013 8:49:37 AM • JBL Music • Answered on Nov 22, 2013
No vocals on jbl
Would you please add a bit more info as this tells me nothing, kind of appliance you are talking about, model number, speakers used, hook-up arrangement...
11/7/2013 12:48:51 AM • JBL Music • Answered on Nov 07, 2013
Every time I try to use 1/4 cables the eon 315s
If you use 1/4 inch cables they MUST be TRS cables (balanced lines). Guitar cables that do not have the third contact (ring) will have buzz and hum. Use either XLR or TRS cables. Also power the speakers and mixers from the SAME receptacle as the speakers.
5/24/2011 11:32:01 PM • JBL Music • Answered on May 24, 2011
Jbl Eon 515 Eon515 15 Powered Portable Speaker PA Dj Logo
Popular Tags
14 questions posted
Top JBL Music Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a JBL Music Expert? Answer questions, earn points and help others
View Most Popular
JBL Music
  • JBL Music
Most Popular Question
loud buzz hum started jbl eon 1500
  • Music
