20 Most Recent Mackie Srm450v2 Srm V2 Active Speaker Srm450 12 PA New Questions & Answers
Mackie say this is not a user service part. If the fuse has blown there is probably a fault in the unit being their reasoning. I know for certain they tend to blow for no apparent reason so it is worth giving it a go. They are 5 x 20 Slow or time fuses. 7A for 120V and 4A for 230V
Mackie Srm450v2... | Answered on Feb 18, 2014
If you've changed the tweeter and the sound is still muffled the fault is with the HF amp, or the cross-over. You will have to send the amp assembly for repair as it is all surface mount components in there -nothing you will be able to fix yourself. Sorry for the bad news!
Mackie Srm450v2... | Answered on May 05, 2011
Getting very muffled sound usually could be attributed to either the cables supplying the speakers being bad or torn speakers. The cable problems usually should be traced as far at where they get connected to the unit as a breakage in any of them could cause such problems in the speakers.
Secondly the main speakers in the speakers could be torn therefore the bad sound being produced try to get all the component speakers checked to ensure that they are all okay. if after checking these the speakers are found to be good then try an alternative sound souurce to ensure that the problem is not from the sound source instead of the speakers.
Hope this solution has been helpful?
Mackie Srm450v2... | Answered on May 04, 2011
Chances are if the fuse has blown, there are failed electronic components that caused the failure.
Here is a service manual that will be CLOSE to your unit, though not exact:
http://elektrotanya.com/mackie_srm450_active_speaker.rar/download.html
Scroll down to the "Get Manual" on the site and click on the link. The file is compressed. The first part is the schematic, the second the assembly and parts list. Likely the main low freq power amp has shorted transistors.
Mackie Srm450v2... | Answered on Apr 24, 2011
There is an entire crossover circuit inside that is BEFORE the amp section. There are 2 separate amps: one for HF and one for LF. Can you describe the noise you are hearing in more detail? Is hte sound effected by the gain controls at all? What happens without any input?
Thanks,
Dan
Mackie Srm450v2... | Answered on Feb 13, 2011
You probably have issues with caps in the power supply....I would check that first...open it up and look for buldging caps and replace any that you find....
Mackie Music | Answered on Sep 27, 2019
Here you go
http://www.mackie.com/products/onyx4bus/pdf/Onyx_4Bus_OM.pdf
This link to the manual is on the Mackie website
Mackie Onyx 32 4
Mackie Music | Answered on Jun 08, 2019
Hello, check if your Mackie, is with the latest Firmware update, you can get it on Mackie's official website
I sent you the Mackie technical support link
I hope you solve your concern
Greetings Franco Dosil
Hola, revisa si tu Mackie, esta con la ultima actualizacion de Firmware, puedes obtenerla en la pagina oficial de Mackie
Te envio el link del soporte tecnico de Mackie
Espero logres resolver tu inquietud
Saludos Franco Dosil
https://mackie.com/blog/support
Mackie Music | Answered on May 03, 2019
Hello Abel, I sent you the link to download the service manual of the Mackie PROFX16
I hope you can solve the problem you have with your Mackie
Hola Abel, te envio el link para que descargues el manual de servicio de la Mackie PROFX16
Espero que puedas resolver el problema que tengas con tu Mackie
https://elektrotanya.com/mackie_profx16_profx22_sch.rar/download.html
First thing to do is get a can of contact cleaner. Take off the knobs and spray it into the reostats below. Spray into all the switches and even into the sliders. Move everything back and forth - 0 to 10 (to clean them). If we're lucky, that will fix it.
Good Luck
Mackie Music | Answered on Dec 26, 2018
First, unless you are a trained or self-taught audio technician, don't attempt to repair the unit yourself. Let the professionals repair it. You can damage it beyond repair if you don't know what you're doing.
Non-working channels are caused either by bad connections, bad solder joints or a dead IC op-amp.
The causes of weak channels can be more challenging to track down. I'd suspect bad connections, dirty controls or connectors.
Mackie Music | Answered on Nov 06, 2018
Glenn, Does it say 'overvoltage', or simply 'voltage'? For the clearest result brother, contact Mackie - 1-800-898-3211 is their tech line - they're super cool - I just always picture the guys at Mackie sitting around reading comic books and shooting guns into the air. good luck!
Mackie Music | Answered on Sep 29, 2018
Mackie Srm450v2 Srm V2 Active Speaker Srm450 12 PA New Logo
12 questions posted
Top Mackie Music Experts
Michial Gueffroy
 Grubhead
Grubhead
Joaquim Martins
Are you a Mackie Music Expert? Answer questions, earn points and help others
View Most Popular
Mackie Music
  • Mackie Music
Most Popular Question
problem mackie srm450v2 hfsignal
  • Music
