20 Most Recent
Peavey Delta Blues 115 30w All Tube Combo Guitar Amplifier Questions & Answers
It rattles....even with the grill
There could be a small tear in the plastic liner over the speaker. If thats the case you can try pressing some cotton on it and then put the grill back in place, or find some fabric glue and glue a thin peice of fabric over the tear.
Hi there, and thanks in
DO NOT run on less than the full set of valves!!! ALSO when replacing the valves with matched pairs used the matched pairs to replace either the inner two or the outer two. If they come loose, the sockets probably have pins that are loose. Sometimes they can be
tightened a little using a sharp scribe to bend them gently inward. I would consider installing tube retainers. They are made as a wire springs. Go to this site:
http://www.tubesandmore.com/
Click on "Vacuum tube Accessories"
While playing sound totally stopped.
The preamp tube fillaments are run from DC with all three in series. The 36 volts for the heaters come through a 15 ohm power resistor. Check voltage across C46. You should find about 36 volts. if that voltage is there, one of the 12AX7 tubes has burned out one of the heaters and like a series Christmas light set, the string is all dead. Here is the problem: Various brands of tubes will vary in heater current and as such replacing one of a different brand may cause it to not take its share of the heater voltage, either more or less. So sorry to say, you should replace ALL three of the 12AX7's with the same brand tube and preferably from the same production lot at the same time. If you happen to find the voltage across C46 is way below the 36 volts, cease to use the amp until the cause is repaired since this voltage is also used in biasing the power tubes. The arrangement they have used in this amp is stupid as far as the heater circuit and having these in series... I would have fired the designer.
After playing for a while,
Such a long delay and a slow return to volume is puzzling. If the return came back in say 30 seconds, I would suspect 1/2 of the V1 tube (12AX7) might have a failure of the heater. When it has failed see if this tube has TWO points of light in it. The cooling down and warm up would give a 15 second ramp up or down in volume. This tube has a path around it that would sustain a very low volume. Try swapping one of the other 12AX7's into this spot. If the sound totally goes away replace the one that was in V1 at first place and see if problem goes away.
Peavey 14 bt mixer won't pan. Keeps sending signal to both outputs
If your Peavey 14 BT mixer is not allowing you to pan the audio signal and is sending the same signal to both outputs, there could be a few potential reasons for this issue. Here are some troubleshooting steps you can take to address the problem:
1. **Check the Pan Controls:** Make sure you're using the correct pan controls for the channels you're trying to pan. The pan controls are typically knobs labeled "Pan" or "Balance" on each channel strip. Ensure that they're set to the desired positions.
2. **Reset Pan Controls:** If you've already adjusted the pan controls and they're not working as expected, try resetting them to their center positions. This can help eliminate any accidental settings that might be causing the issue.
3. **Channel Routing:** Some mixers have routing options that can affect panning. Check if there are any routing switches or buttons that might be affecting the signal routing for each channel.
4. **Mono/Stereo Mode:** Some mixers have a mono/stereo mode switch that can affect panning. Make sure the mixer is in the appropriate mode for your setup.
5. **Master Pan Control:** Ensure that the master stereo output pan control is set to the center position. If it's panned to one side, it can affect the overall stereo output.
6. **Test Different Channels:** Try panning different channels to see if the issue is specific to one channel or affecting multiple channels.
7. **Firmware/Software Update:** If your mixer has digital components or software control, check if there are any firmware updates available. Sometimes, software updates can address functionality issues.
8. **Physical Damage or Wear:** Inspect the pan controls and associated circuitry for any physical damage or wear that could be causing the issue.
9. **Factory Reset:** If none of the above steps resolve the issue, you might consider performing a factory reset on the mixer. Be sure to back up any important settings before doing this.
10. **Professional Service:** If the problem persists after trying these steps, it might be a more complex internal issue that requires professional servicing. Contact Peavey's customer support or a qualified audio technician for further assistance.
Remember that the exact steps and controls can vary depending on the model of your Peavey mixer. Refer to the user manual for your specific model for more detailed information on troubleshooting and operation.
8/20/2023 2:15:59 PM •
Peavey Music
Answered
on Aug 20, 2023
Does the peavey xr-600b have phantom power
It does not have built-in phantom power. Phantom power is a method used to provide power to condenser microphones and other devices that require a small amount of power to operate.
It is important to note that the XR-600B have XLR inputs which are typically used for condenser microphones that require phantom power but it does not provide this feature. If you want to use a condenser microphone with the XR-600B, you'll need an external phantom power supply or an audio interface that provides phantom power.
1/12/2023 8:34:18 PM •
Peavey Music
Answered
on Jan 12, 2023
Peavey bass R1080052 looking for any info .
Peavey R1080052 is a bass guitar model produced by the Peavey company. It is part of the company's Classic series of instruments, which are designed to offer vintage-inspired tones and aesthetics at an affordable price. The R1080052 features a solid ash body, a maple neck with a rosewood fingerboard, and two single-coil pickups. It also has a vintage-style bridge and a set of open-gear tuners. This bass is known for its warm, punchy sound and comfortable, easy-to-play feel.
1/10/2023 12:11:58 AM •
Peavey Music
Answered
on Jan 10, 2023
