20 Most Recent Boss ME25 Guitar MultiEffects Pedal with AC Power Supply Samson HP10 Headphones and (2) Sonic Sense Instrument Cables Questions & Answers
2answers
Adapter polarity
Boss ME-25, use polarity like boss stompbox. + voltage at the ring, and - voltage at the center pin, of the adapter connector. ..20023597-2ss5ycyvkoajtv035dpuezke-5-0.jpg At ME-25 DC socket: 20023597-2ss5ycyvkoajtv035dpuezke-5-3.jpg 20023597-2ss5ycyvkoajtv035dpuezke-5-6.jpg
5/10/2016 3:02:28 PM • Boss ME25 Guitar... • Answered on May 10, 2016
How to reset the pedal
You can restore the settings in the ME-25 (memories, tuner
reference pitch, and knob response method) to the values set when
the unit was shipped from the factory.
Performing a factory reset causes all settings saved in memory to be
lost. If you want to keep the memory settings, use the ME-25 Librarian
(p. 11) to save them on a computer.
1.
Hold down [EXIT] and press the MEMORY DOWN
pedal at the same time.
"FA" appears in the display.
2.
Press [WRITE].
The Tuning Guide flashes.
3.
Press [WRITE] again.
The display flashes and the factory reset is executed. Never turn off the power while factory reset is in progress.
10/15/2012 11:56:18 AM • Boss ME25 Guitar... • Answered on Oct 15, 2012
AC power supply polarity for
Center negative. 9.6 VDC 500ma Boss PSA-120S is official adapter.
3/7/2011 7:47:57 AM • Boss ME25 Guitar... • Answered on Mar 07, 2011
I think I may of
Swapping the leads of input and output will cause NO damage. Just connect them correctely... output of pedal to the input of the amp.
1/22/2011 5:42:49 PM • Boss ME25 Guitar... • Answered on Jan 22, 2011
When i'm on clean sound
A lot of pedals when on bypass actually just connect the signal straight through... WHILE when using the effect, the volume control parameter is active. You need to balance the effect volume control against the straight through level which you have no control over.
1/8/2011 12:59:31 AM • Boss ME25 Guitar... • Answered on Jan 08, 2011
1992 Ford Boss 260 accelerator pedal removal how to do it
This may help. https://www.youtube.com/watch?v=ptlE2_B3ZlA
12/31/2023 10:36:00 AM • Boss Music • Answered on Dec 31, 2023
Best sound for dsl15h and MT-2
To achieve a tone similar to Synyster Gates' A7X sound, you may want to start with the following settings: Green channel:
  • Bass: 5-7
  • Mid: 2-4
  • Treble: 5-7
  • Presence: 5-7
  • Gain: 7-8
Red channel:
  • Bass: 3-5
  • Mid: 3-5
  • Treble: 5-7
  • Presence: 5-7
  • Gain: 8-10
When using the Boss MT-2 pedal, set the tone control to around 12 o'clock and the level to taste. This should give you a good starting point for a heavy metal tone. It's important to note that these settings are just a starting point, and you may need to tweak them to suit your own personal taste, playing style and the room you're playing in. Keep in mind that the MX112 cab will also affect the sound,so you may need to play with the eq settings on the head and the pedal to achieve the sound you are looking for. Also, keep in mind that the sound of the DSL15H head with the MX112 cab will be different than the sound that Synyster Gates gets with his rig. However, the settings above should help you achieve a similar overall tone.
1/29/2023 4:52:24 AM • Boss Music • Answered on Jan 29, 2023
Cube Baby and Boss ME-25?
Question edited to make some sense :>D https://www.google.com/search?q=Cube+Baby+and+Boss+ME-25 ..
11/20/2022 1:37:37 AM • Boss Music • Answered on Nov 20, 2022
MG50CFX. Why is fx loop almost silent?
Loaded with a custom 12" speaker, the MG50CFX delivers that iconic ... Take control of your tone with a range of digital FX and four footswitchable channels. ... also has a dual function headphone socket for silent practice or silent recording. ... Effects. Reverb, Phaser, Flanger, Delay, Chorus. Effects loop. for more visit https://travismoviereviews.blogspot.com/2021/04/in-earth.html
5/2/2021 6:15:28 AM • Boss Music • Answered on May 02, 2021
What 9v to ac adapter do i need for a boss distortion pedal ds-1
9V AC Adapter for Boss DS-1 Distortion Guitar Effect Pedal ...
www.amazon.ca > Adapter-Distortion-Guitar-Effect-Ch...
9V AC Adapter for Boss DS-1 Distortion Guitar Effect Pedal Charger Power Supply. AC Input 100V-240V 50-60Hz;DC Output. Industry Quality : Over Voltage Protection, Over Heat Protection. Brand New Adapter, 100% Compatible. Warranty:1 year warranty, 30 day money back guarantee. Shipping from USA !
Accessory USA 9V AC Adapter for Boss DS-1 Distortion Guitar ...
www.amazon.com > Accessory-USA-Adapter-Distortio...
Accessory USA 9V AC Adapter for Boss DS-1 Distortion Guitar Effect Pedal Charger ... D'Addario Accessories PW-CT-9V DC Power Adapter - Minimize Need to ... Rating: 4.3 · ‎15 reviews
12/17/2020 7:59:21 PM • Boss Music • Answered on Dec 17, 2020
MY BOSS GT10 IS DEAD. IT'S JUST FLASHING THE SCREEN. CAN ANYONE GIVE ME THE CIRCUIT DIAGRAM OR CAN ANYONE TELL ME HOW CAN I FIX THIS
The GT-10 looks easier to operate with its new EZ tone wizard, have you watched the video? ... To me, it's as if the Roland amp modelling is put through a 1980s process that ... it sounds good but i don't know if it can beat pod x3 live. i'd like ... given by balanced lines and the cost introduced by the extra circuitry they require.
11/20/2020 12:53:45 PM • Boss Music • Answered on Nov 20, 2020
My boss br-1180 out put is distorted its fine with head phones i tried all the basics stuff to solve the problem with no luck
Can you get a cable adapter from somewhere like ShowMeCables similar to this: https://www.showmecables.com/by-category/adapters/audio-video-adapters/3-5-mm/3-5mm-stereo-male-to-dual-1-4-in-mono-female-adapter-cable-6-in Use the headphone out and plug your amp into the left channel of the adapter.
6/14/2020 8:22:23 PM • Boss Music • Answered on Jun 14, 2020
BOSS ME 70
A multi-effects unit that's as easy as a stompbox - that's the beauty of the new ME-70. The friendly, knob-laden design makes tone creation a snap, but with a powerful COSM AMP section derived from the GT-10, the ME-70 takes the "EZ effects" concept to new heights.
5/22/2020 1:57:47 PM • Boss Music • Answered on May 22, 2020
My BOSS ME-25 is muted, no sound, the display is off, no LED is on.
I think your headphones got a defect. visit nearby repair shop to know what`s wrong with your headphones in detail.
3/19/2020 3:59:19 PM • Boss Music • Answered on Mar 19, 2020
BOSS RC-20XL LOOP STATION: recording time should be free; now it automatically stop recording after about 30 seconds.
https://www.youtube.com/watch?v=SOWO8wUpqvE
3/9/2020 6:08:10 PM • Boss Music • Answered on Mar 09, 2020
2answers
Replace battery in Boss bup2 controller
1. First remove the backplate from the BUP2 by undoing the two small screws at the base of the unit and lift out from the bottom so that the two lugs at the top disengage from their positions. 2. Prior to installing onto the backplate, insert the battery into the battery tray and ensure that positive + and negative - are correctly installed. The battery is a non-rechargeable lithium cell and in the event of power failure will protect your programme instructions for up to 365 continuous days of power loss. 3. The BUP2 is factory set to provide 2 on/off switching periods per day and each day will be the same, i.e. daily operation. To select the other styles of switching you will have to alter the dip switches which are to be found at the bottom rear of the unit into the relevant position for the style of operation you require.
2/11/2020 6:09:22 PM • Boss Music • Answered on Feb 11, 2020
Boss ME25 Guitar MultiEffects Pedal with AC Power Supply Samson HP10 Headphones and (2) Sonic Sense Instrument Cables Logo
Popular Tags
11 questions posted
Top Boss Music Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a Boss Music Expert? Answer questions, earn points and help others
View Most Popular
Boss Music
  • Boss Music
Most Popular Question
reset pedal
  • Music
