20 Most Recent
Moultrie Feeders Catagory Electronics Instruments Cameras (Game Spy I65 S Digital) Questions & Answers
My D55IR-P will not transfer pictures to any SD card?
Make sure it has not been in a digital camera if has been moultire will not read it again because of the format files. If you using anything that says pny, ultra highspeed optima or micro not compitable. Sandisk, lexar and moultire what works best.
I can't find software updates
The only upgrades Moultrie has is for the D55 and D55IR models...and these only reduce trigger speeds...no other software updates available yet.
Camera is not reading card
remove the card and put it back into the camera. The card should spring when inserted into the camera. When it springs, it means it is inserted correctly. So add more force and it will key into the camera.
Now if the camera does not recognize the presence of the card, insert the card into another device or computer in order to confirm if the card is good. Also, insert another card into the camera, to know if the card reader of the camera is function properly. The out come of these test will determine where the problem is coming from.
Blow some air into the card slot of the camera in order to discard debris or dust that may be disturbing the card from contacting the camera very well.
Lastly, if you feel the card is not inserted correctly, remove the card and fit it into the camera, the other way round. It should seat correctly by then. Also,don't forget the that card will kind of spring when inserting it into the camera. This is a sign that it is being inserted correctly.
Keep me posted.
Regards.
My doorbell has gone quiet
It may have this silent option in either choice for volume or melody. My doorbell has numbered buttons that need to be pressed together with the button to open the door, in order to access these functions.
Another thought is that a battery needs to be replaced.
