20 Most Recent
Bebecar Tracker Urbano 1455-U Stroller Questions & Answers
Comment changer la position du
Appuyez sur le bouton rouge et tourner le bouton tout en soulevant le siège hors du cadre. Le siège peut faire face avant ou en arrière. Placez le châssis de siège dans les points de fixation de chaque côté. Quand il s'agit de ce qu'il se verrouille automatiquement. Veiller à ce que les coureurs cadre du siège sont en sécurité dans les quatre points de fixation.
How do i put the
It sounds like you need instructions for the particular adapter kit that you have for fixing the car seat to the Tracker chassis. You may have a Universal Fixing Kit or it may be an earlier version designed just for the Tracker.
You should get in touch with
[email protected] - perhaps send them a picture of the kit that you have, if you can. They'll be able to offer instructions and advice.
How do i fit the bebecar tacker car sit in the car
"Tracker" is really a model of Bebecar chassis, rather than of a car seat. It would be good to know exactly what model of car seat you have. Your best plan would be to get in touch with
[email protected]. Send them a picture of your car seat if you can. They will be able to make instructions available to you, with helpful diagrams.
How do i fold this
The Tracker is designed to be folded and unfolded easily, by one person.
To unfold: If your Tracker has an adjustable handle, ensure that it is in one of the middle positions. On the central twist grip, push in the red button and turn the grip in the direction of the "FOLD" arrow. The pushchair should now begin to open. Placing your hand on the side moulding, pull on the handle until the primary locks on both the left and right hand sides engage with a click. The secondary lock should automatically engage.
To fold: First of all, make sure that the front wheels have been locked into fixed, non-steering mode. Also, ensure that the adjustable handle is in one of the middle positions. Press the red button on the twist grip and simultaneously turn it in the direction of the "FOLD" arrow. At this point, the chair should start to close. Next, look for the secondary locking device. This plastic tab should be situated just below the handle grip on the left-hand side. Pull it upwards, whilst tilting the chassis forwards and continuing the folding action until it is fully closed. Align the front wheel with your foot, if necessary, and fold down the adjustable handle to store the chassis.
Find out more by obtaining an instruction manual from [email protected]
How do you put up the bebecar tracker urbano
If your Tracker has an adjustable handle, ensure that it is in one of the middle positions. On the central twist grip, push in the red button and turn the grip in the direction of the "FOLD" arrow. The pushchair should now begin to open. Placing your hand on the side moulding, pull on the handle until the primary locks on both the left and right hand sides engage with a click. The secondary lock should automatically engage. Find out more by obtaining an instruction manual from
[email protected]
Cant fold my adventure raider at+
get in touch with east coast nurserys they are the distubitors for bebecar. or if you live in london get in touch with www,buggypitstop.co.uk and they will fix it for you
Zip in rain cover for bebecar tracker
Hello, if you put the make of the strler in on GOOGLE you should be able to trck down the manufacturer, they in turn may sell you on. The other way is to try E-Bay, you may be able to find one in the many stores that are on there.
I hope this is of some help.
Bebecar adventure
There should be a grey button on the side, press it to lock the wheels if i remember correctly.
on the main body of the pram (big plastic bit) where the handle goes into the body, not down at the wheels
Its been a while since i used this one
GP
