20 Most Recent
Hilti 120-Volt SDS Max Demolition Hammer TE 500-AVR Performance Package 3484551 Questions & Answers
I have a te 500 it not knocking at full strength
A Broken front ring which blocks the lock bolt ?
Is there enough lubrication flow if something is broken inside replace ALLWAYS a complete servicekit , because its , beware of the Turmopol oil is expensive. there are equivalent oils if you asked special for it also by Hilti to buy.
Hilti and Duss are not the 2 cheapest brands of powertools.
Special Tolerance-free bearings are used it is all super calculated on a number of operating hours and about if something is defective, a complete overhaul is necessary.
These hammers may leak no trace of oil in the front until 2006 HILTI has in my Country support , but after this date
exclusively support to the end-users and support closed for brokering.
The transformer/control pack housed within the
Billy-
Replacement parts are no easily found without going through one of Hilti's authorized repair service centers. Visit www.Hilti.com to find one near you - you may be able to purchase the part directly from the service center. Maybe its worth it you you to have them do the work as well - Hilti tools have a great lifetime warranty and service repair policy:
LinkHope this helps.
Regards,
DIYpro
Trigger switch on te22 dead.can
you can go to Hilti direct or find a local dealer by going to "hilti.com" or calling them at 1-800-879-8000 and you can get the replacement. I would not try another switch.
