20 Most Recent Sharp EL-2630P Calculator Questions & Answers
Change date sharp el-2630PIII
"GT": Grand Total
"•": Neutral
" ": To set up date, time, conversion
rate, and tax/discount rate, place the
switch at the "RATE SET" position.
Date:
• Enter in the order of month, day
and year, then press to
complete the entry.
• Use to separate month, day,
and year.
• When is pressed, the number
entered is evaluated and displayed
as "date" if the value is within the
following range; "Error" is
displayed otherwise, and the
previously set date is restored.
Month: 1 - 12; day: 1 - 31; Year:
2000 - 2099 (in 4 digits) or 00 - 99
(in 2 digits)
Time:
• Enter in the order of hour, minutes,
then press to complete the
entry.
(There is no entry available for the
seconds value. The clock starts at
zero second.)
• If the hour/minute digit is less than
10, it is not necessary to enter the
first digit "0".
• Use to separate hour and
minute values.
as "time" if the value is within the
previously set time is restored.
Hour: 0 - 23 (24-hour system for
the hour entry), Minute: 0 - 59
1/9/2018 8:09:11 PM • Sharp EL-2630P... • Answered on Jan 09, 2018
0answers
Tape feed
Be the first to answer 9/13/2017 5:09:03 AM • Sharp EL-2630P... • Posted on Sep 13, 2017Be the first to answer
How do I clear a paper jam in my Sharp EL-2630PIII adding machine?
My paper is stuck and jammed in the feeder. I cant add new paper because of the jam. The new paper crinkles up as it feeds. Is there a way to remove the jam of paper that's stuck inside ?
2/8/2016 3:22:51 PM • Sharp EL-2630P... • Answered on Feb 08, 2016
How do you put the adding machine tape into the
Put the leading edge of the tape into the the opening on the back of the machine. Turn the machine on and press the button with the up arrow, then lift the little metal paper holder and insert the roll.
4/14/2015 6:39:24 PM • Sharp EL-2630P... • Answered on Apr 14, 2015
How do i get my decimal point back to where it was before.
Find the switch labeled "F 6 3 2 1" and also the switch "K . A" K means CONSTANT and A means ADD. I always use: A and 2 on the switches, to get 12.34 when 1234 is entered, for example.
11/29/2014 9:28:05 PM • Sharp EL-2630P... • Answered on Nov 29, 2014
0answers
Sharp EL-2630P Calculator Logo
210 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
want set decimal place without using
  • Office Equipment & Supplies
