20 Most Recent
Sharp FO 5700 Plain Paper Laser Fax Questions & Answers
FO 5700 Won't print from memory
You have memory lock up. to ram clear the machine we need to clear out all memory. ( like it came out if the box )
1. have machine turned on
2. press 8,*,9,#.7 ( this will git you in to the programing of the fax )
3. press start
4. press the # key till memory clear
5. press start !( will clear out all memory )
it should print out a memory clear report
6 press stop key 2 times now lets se how it worked
let me know
good luck
Sharp FO5700
I have never seen this error code on a sharp FO 5700 are you sure that is the right model # or error code. I even did a search in the FO5700 service manual(no luck). I believe I have seen this code before on a sharp copier.
Sharp fo 4700 display error ( polygon )
You have a bad printhead unit(laser unit) . The polygon mirror is not rotating within a specific amount of time. I recommend you to replace your fax unless your willing to spend between 200 to 500 dollars.
Error message
when you look at the front of the fax. above the paper cassette there is a gray,blue cover where the paper comes out when receiving or coping , that cover needs to be seated properly there is a mag switch that will shout down machine till it is in place.
Never have I seen this sensore go oit just the cover is out of position,
hope all will be OK
I get a partial copy when using my Sharp FO 5600
Make a copies with something with a lot of print. open top cover when the paper is 1/2 way through the machine. pull out the toner & drum unit's look at the drum is there a full image on the drum but not on the paper then it is a transfer problum. If no image on the drum then we have a laser unit problum. There is a shutter that opens when you put the drum in & closes the top cover. it may fallin out of place. hard to git at or somthing is blocking the laser beam ( paper, dust bunnyies or fourn objest ) hope this helps let me Know
C.W.H.
