20 Most Recent MXR Carbon Copy Analog Delay Pedal Guitar Questions & Answers
Carbon copy failure ?
4/17/2023 4:24:15 PM • MXR Carbon Copy... • Answered on Apr 17, 2023
Must I remove battery when using auxiliary power supply?
I can't see any reason to do that unless the battery gets old. When you plug in the adapter, it automatically switches off the battery.
3/29/2014 3:17:09 PM • MXR Carbon Copy... • Answered on Mar 29, 2014
0answers
I just got an MXR
Most common problem is the in and out cables are backward to cause this.
7/6/2011 7:33:39 PM • MXR Carbon Copy... • Answered on Jul 06, 2011
I'm getting a drastic level
First thing to test: Do all the controls vary their function smoothly or does say the volume control vary the output only slightly. If the latter condition exists I would open the pedal and look for broken solder around one lead of the volume pot. The broken solder is hard to see... look for a little grey line on the menicus of the solder filet around each lead. Also look for cracks in the circuit board. Use a bright light.
5/6/2011 1:23:17 AM • MXR Carbon Copy... • Answered on May 06, 2011
I was jamming, getting a
DO NOT count on a "new" battery to be good! I always carry an inexpensive meter (about $3 from Harbor Freight) to test batteries. Try yet another battery...
A common failure however is that the wires to some of the battery clips break after having to fight with 9 volt battery clip removal that have wires... The ones without wires have a habit of not making contact at time...
12/31/2010 9:56:42 PM • MXR Carbon Copy... • Answered on Dec 31, 2010
0answers
I have the first serie MXR Distorsion and the
Here is a schematic that may help:http://www.schematicheaven.com/effects/mxr_dist_plus.pdf
11/30/2009 9:39:22 PM • MXR Music • Answered on Nov 30, 2009
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM • Music • Answered on Feb 07, 2024
2answers
FRONTIOPAE what is this instrument unscrambled
'pianoforte'
1/17/2024 4:22:56 PM • Music • Answered on Jan 17, 2024
Looking for specific screw for a Crate and Barrel table
BREV. N. 838420
1/9/2024 8:32:24 PM • Music • Answered on Jan 09, 2024
I want to manually wire my z-560
1/4/2024 1:18:20 PM • Music • Answered on Jan 04, 2024
Electronic drum
See page 22 troubleshooting of this manual. It may help you. dd501 (yamaha.com)
1/3/2024 2:26:52 PM • Music • Answered on Jan 03, 2024
No or very little sound from Fender passport
Depending on the model, there are four around that date, it could be the insert jacks are tarnished reducing the signal flow between the pre amp stage and digital power amplifier. It could be the power amplifier has failed. It could even be customer error in wiring. This assumes there is the correct level of signal entering the input sockets of course.
12/31/2023 8:25:12 AM • Music • Answered on Dec 31, 2023
What song did these lyrics come from. (You can set by the water but you just can't drink )
Are you sure you are quoting accurately? Could it be one of these instead? http://www.lyrics.cat/lyrics+lead+a+horse+to+water
12/27/2023 3:43:51 PM • Music • Answered on Dec 27, 2023
Line 6 spider ii head sounds like crap on insane red setting
It's a Line 6 and probably requires a software update from Line 6.
12/24/2023 7:57:43 AM • Music • Answered on Dec 24, 2023
MXR Carbon Copy Analog Delay Pedal Guitar Logo
Popular Tags
8 questions posted
Top MXR Music Experts
Liza Cat V
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a MXR Music Expert? Answer questions, earn points and help others
View Most Popular
MXR Music
  • MXR Music
Most Popular Question
must remove battery when using auxiliary
  • Music
