20 Most Recent
Jackson Rhoads RR3 Guitar Electric Questions & Answers
My RR3 Jackson Guitar has corrupt sound.
It may be the nylon strings are not compatible with your pickup. The pickups rely on varying magnetic fields from the strings to produce the sound- nylon is not magnetic unless doped with a ferrous material.Either find doped strings, find a way to dope them or switch back to steel.You can check the pickups themselves indirectly with a soldering gun or tape head demagnetizer held close to them- you will hear the line frequency quite well if the pickup is working.
Hello i have a jackson
I would suspect the tremelo hardware is not returning to rest at the same point. Look for rubbing points and maybe lightly lube those... very sparingly.
I have a Jackson bass guitar bought almost two
I would say, that it probably needs a new 9V battery. It had some time to gain some juice after the gig. If a fresh one doesn't help, then the problem could've been the equipment or power outlet distribution at the gig site.
