20 Most Recent
Roxio Creator 2011 Questions & Answers
Roxio creator has stopped working
- Please be sure that you have met the system requirements of Creator.
- Defragment your hard drive. This will allow larger files that you
have created to be more easily read by the program and allow more
efficient writing of data for video and audio capture to your hard
drive. To do this:
- Go to Start -> All Programs -> Accessories -> System Tools -> Disk Defragmenter.
- In the Disk Defragmenter window, select the drive (a.k.a. volume) you wish to defragment.
- Note the Free Space column. If you have less than
10% free space available you may run into issues
defragmenting. Additionally, the drive is too full to capture
any new media to it. Doing so may result in the hard drive
crashing and data loss. Unless more free space can be safely
made, it is recommended that you purchase an additional hard drive
just for your multi-media projects.
- Click the Defragment button.
NOTE: If frequently using your computer for recording and editing
audio and video, defragmenting your hard drive on regular basis
(about once a month) is recommended.
- Contact your video card manufacturer for the latest video card
drivers. If you purchased your computer as a complete system (like Dell
or HP), then go to the manufacturer's website for the latest drivers.
If you purchased your video card separately, then you will need to
find out your make and model and go to the video card manufacturer's
website to download.
- Windows XP: Go to My Computer and choose Properties.
- Windows 7 and Vista: Go to Start -> Control Panel -> System and Maintenance -> Device Manager.
- Click on the Hardware tab.
- Select Device Manager
- Double-click Display Adapters. You're video card make and model is displayed.
- To find out the driver details (such as version), right click on the make and model under Display adapter, and select Properties.
- If running Easy Media Creator for the first time, or it's been
a while since you used it, RoxWatch will require a few minutes to
index your hard drive for new audio, video, or photo files. This
allows Media Manager to create a convenient list of all the files
you can create projects with in a single window. Once the indexing
is completed, Easy Media Creator will launch faster only looking
for newer files. However, if you wish to disable this function, do
the following:
- Windows XP: Go to Start -> Run -> and then type "msconfig" and click OK.
Windows 7 and Vista: Click on Start -> type "msconfig" in the Search field and press Enter on your keyboard.)
- In the System Configuration Utility window, select the Startup tab.
- Locate RoxWatchTray10 (or whichever version you are using) under the Startup Item column and uncheck it.
- Click Apply and then OK.
- Reboot your machine.
- On reboot, you will receive a dialog from the System Configuration Utility. Check the box at the bottom of the window requesting not to see the dialog again and click OK.
- Launch Creator.
Recently bought & installed Roxio 2011 on
If you are getting the error at startup, roxio service might not started or disabled. What you can try to do is to enable all roxio service. refer to the steps below.
- click start > run
- type services.msc
- look for all roxio service i.e roxwatch.db
- double click it then select the startup type to automatic
- save the changes then restart computer
Cheers . . .
Creator 2011 says it is
Based on the Microsoft Website
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Search.aspx?l=en-us&type=Software&s=roxio%20creator%202011
Roxio Creator Pro 2011 is compatible with windows 7 so all you need to do is call Roxio and check if there is a discount for the Pro version since you already have the Creator 2011 and upgrade to Roxio Creator Pro 2011.
You can call this number: 877-793-7471 (North America only)
I am having trouble re-downloading my roxio
Roxio is usually bundled with a specific model laptop or desktop, it does a quick check to ensure that the model machine is what the CD was shipped with. If this check fails it will not allow you to install. My advice, go out and buy Nero Lite, it is pretty cheap and does everything Roxio does but with less of the bloated installation.
I had to replace my
drive. To do this:
the following:
- Launch Creator.
