20 Most Recent
Sharp BQCXVZ100001 Projector Lamp for XV-Z10000 Questions & Answers
How to reset the timer on a sharp BQCXVZ1001 when changing bulb
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
9/28/2016 8:40:16 AM •
Sharp...
Answered
on Sep 28, 2016
XV-Z10000I change the lamp with a new one it
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
8/26/2016 4:14:37 AM •
Sharp...
Answered
on Aug 26, 2016
My projector wont turn on and the lamp light is
Have a nice day!
Jerry
Lampdeng Limited
8/26/2016 4:12:14 AM •
Sharp...
Answered
on Aug 26, 2016
Sharp xvz-10000 projector.\r\nI replaced the lamp
Have a nice day!
Jerry
Lampdeng Limited
8/26/2016 4:11:46 AM •
Sharp...
Answered
on Aug 26, 2016
Sharp projector
Thanks for the rating. if you need further assistance just select the ASK ME button
1/5/2009 6:24:57 PM •
Sharp...
Answered
on Jan 05, 2009
System lock of my projector sharp 50s ,so how to unlock?
- Check the Remote: Make sure you have the remote control for the projector.
- Press the Menu Button: On the remote, press the "Menu" button.
- Navigate to Security or System Lock: Use the arrow keys on the remote to navigate through the menu options. Look for a section related to "Security" or "System Lock."
- Enter the Unlock Code: If you previously set a system lock code, you will need to enter it using the remote control. If you haven't set a code before, try the default code (often 0000 or 1234).
- Disable System Lock: Once you've entered the correct code, navigate to the option to disable or unlock the system lock.
- Confirm: Follow the on-screen instructions to confirm your choice, and the system lock should be disabled.
Sharp EL-1197PIII printing nonsense after a jam.
Reset the calculator: Locate the reset button on the bottom or in the battery compartment and press it .
Clean the printer head: Use a soft, dry cloth to clean the printer head and ensure that there is no debris or paper stuck in the printer mechanism .
you are looking for resources to properly align the gears. I found a few resources that might be helpful:
Sharp EL-1197PIII Operation Manual: This manual provides detailed instructions on how to operate and maintain your calculator, including how to align the gears. You can download the manual from the following link:
SHARP EL-1197PIII OPERATION MANUAL Pdf Download ' ManualsLib.
Sharp EL-1197PIII User Manual: This manual also provides instructions on how to align the gears of your calculator. You can access the manual online from the following link:
Sharp EL-1197PIII User Manual online (mans.io).
Sharp EL1197PIII Heavy Duty Color Printing Calculator User Manual: This manual provides instructions on how to align the gears of your calculator. You can download the manual from the following link:
User Manual Sharp EL1197PIII Heavy Duty Color Printing Calc ' manualsFile.
