20 Most Recent
Shop Vac 5841627 Wet/Dry Vacuum Questions & Answers
I can't find the owner's
generally you remove the filter and just use the foam sleeve (if it has one) it should have a float ball in a cage under the filter. this is to keep the water from going into the motor if it gets too full. That is pretty much it. You should have it plugged into a GFCI outlet when using it for wet pick up, also do not pick up flammable or hazardous liquids.
My rigid shop vac 4.0 has no suction
If the motor is turning on then the issue is one of three things blocked exhaust, blocked intake or the fan that moves the air is loose on the motor . The last doesn't happen as much but can. First thing is to make sure the safety ball hasn't become stuck in the intake line. ( this ball stops water from reaching the motor when using it in a wet environment.. If the machine was knocked over while running or was used to suck up water the ball may be stuck) to fix this , remove the wheels from the bottom of the canister , with the machine off raise it and bang it on the floor several times . If you hear a ball drop then that was your issue. If not Disconnect the hose and see if you have suction at the intake. If you do the problem is a blocked hose. Reverse the hose and try sucking the other direction. If the exhaust is blocked the Vac will come on but the machine will sound like it's under load. Try running it without the filters ( do not use in dirt until filter is cleaned and replaced.,). To check the suction fan requires unplugging the Vac from the wall and opening the motor shroud . Locate the fan , see if it is damaged or loose.
The ball in my shop vac gets stuck
Clean the ball and wipe down the thing that holds down the ball. Take a little bit of WD40 and spray a little on the ball and holder. Try that.
Why does the ball inside my shop vac stay stuck
if you are using vac to suck water the ball is a safety device. you must shut vac down and wait you should hear ball drop, if the vac is not in upright position he ball will close shut vac down and wait
