20 Most Recent Sharp AR-M205 Copier Questions & Answers
Hello sir; "L6" display it means laser motor defect need to replace.
Sharp AR-M205... | Answered on Feb 28, 2019
Try reset the code by pressing [#] [Interupt] [C] [Interuptr] [14] [COPY/START]
If error still exist, check the thermofuse and the heater lamp
Sharp AR-M205... | Answered on Sep 09, 2018
Hi
Should probably read H2-00, which is your thermistor in the fuser. Open door on right, three screws hold the fuser in (hot bit), release fuser slightly, being careful as it is still connected, the thermistor is sat in the top, you should be able to reset it by pressing the little button and you should here it click. re-fit fuser and secure.
To reset the code, press these buttons:
Hash, interrupt, clear, interrupt., enter 14, then the print button.
Cheers
Andy
Sharp AR-M205... | Answered on Jun 06, 2018
You polygon motor has failed. It is a pain to replace and kinda pricey, you will want to call a service tech to change it out.
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
Sharp AR-M205... | Answered on Feb 21, 2017
L6 is a motor lock code relating to a paper cassette. There should be a 2 digit code after the L6. Please tell me the model sharp and the 2 digit code and I can help more.
Sharp AR-M205... | Answered on Feb 18, 2017
the tone is it for the machine because the machine is showing that the developer needs to be replaced
Sharp AR-M205... | Answered on Sep 20, 2016
check the main motor belts and gears. hope this helps
Sharp AR-M205... | Answered on Sep 03, 2016
Sometimes the clicking noise can come for the developer cartridge or the drum. you can carefully take them out and see if they turn freely.
Sharp AR-M205... | Answered on Jun 21, 2016
Thank you man but these keys didn't work for me. Guys you can go to https://plus.google.com/103156713044838092165/posts/WBduJyEaG5v to get genuine win 8 keys in a cheap price, I got one there several days ago, it's not bad.
Sharp AR-M205... | Answered on Jun 13, 2016
LSU trouble. Improper connection of the LSU
connector
Check the polygon motor
operation with SIM 25-10.
Check printing with SIM64-1.
Check laser emission of laser
emitting diode.
Check the LSU unit.
Check the MCU PWB
Sharp AR-M205... | Answered on Apr 21, 2016
install the scanner drivers in your computer the connect the machine
Sharp AR-M205... | Answered on Apr 20, 2016
enter # interrupt c # .when display shoes nothing enter 14 and copy .
Sharp AR-M205... | Answered on Feb 11, 2016
decease the density or check the fuser unit (hot part) may ahve previous print burned on its rolllers
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sharp AR-M205... | Answered on Jan 28, 2016
Decrease the density
the man is the maintenance man, the other light is the drum light, the drum needs replacing.
Sharp AR-M205... | Answered on Dec 23, 2015
Here is a link to the driver download page. Under DRIVERS AND SOFTWARE, choose "photocopiers", then scroll down to the model number and select. Then pick either Windows 7 or Windows 7 64-bit as desired. If it won't open a window, right click on the option and choose "open in new tab".
http://support.sharp.net.au/drivers
Sharp AR-M205... | Answered on Nov 22, 2015
See previous answers on this website:
http://www.fixya.com/support/t5481107-sharp_ar_5516_printers_error_h5_h4
Sharp AR-M205... | Answered on Aug 29, 2015
A little more of a description of your problem would be helpful....
Copier Collin Houston TX Copier and Imaging Expert
Sharp AR-M205... | Answered on Feb 10, 2015
Follow the instructions some jams are very hard to see.
Sharp AR-M205... | Answered on Dec 08, 2014
Sharp AR-M205 Copier Logo
409 questions posted
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
l6 code
  • Office Equipment & Supplies
